[postgis-tickets] [PostGIS] #3708: within function gives wrong results
trac at osgeo.org
Mon Feb 13 06:47:51 PST 2017
Reporter: gisdev1982 | Owner: pramsey
Type: defect | Status: closed
Priority: high | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 1.5.X
Resolution: wontfix | Keywords:
Comment (by robe):
More information. I happen to have a PostGIS 1.5.5 lying around and get
true on that:
SELECT postgis_full_version();
POSTGIS="1.5.5" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.7.8"
SELECT ST_Within(st_geomfromtext('POLYGON((61 34,66 34,66 31,61 31,61
34))',101), st_geomfromtext('POLYGON((62 48,83 48,83 29,55 29,55 33,62
48))',101));
st_within
t
So seems your problem might be with GEOS. Upgrade your GEOS and see if it
fixes your issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3708#comment:2>
