[postgis-tickets] [PostGIS] #3699: Nothing downloads edge, faces, featnames, or addr files
PostGIS trac at osgeo.org
Wed Feb 15 21:43:20 PST 2017
  Reporter:  EvanCarroll     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 2.3.2
 Component:  tiger geocoder  |    Version:  2.3.x
Resolution:  invalid         |   Keywords:
Comment (by robe):
 The reason it was marked as invalid was because there is nothing wrong
 with the script.
 It failed because Evan's nationscript load did not complete.
 It could be the black listing that caused Evan's nationscript to fail,
 either way the blacklisting thing is out of PostGIS control.
 Your guess is as good of mine why they black list.  I've got blacklisted
 on both a Linux VM and a Windows physical and virtual box. On various
 networks.  So why it doesn't eventually blacklist for you on one might be
 something dum like the ip range you have is on their white list.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3699#comment:14>
