[postgis-tickets] [PostGIS] #3711: The topology issue an error on azimut function when 3D
trac at osgeo.org
Thu Feb 16 12:06:55 PST 2017
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Keywords: |
working on our rt_topology library we discovered an issue in the topology.
Some tests confirm that the issue is in the original postgis topology.
The issue is triggered when the geometries are with z (3d dimension).
This is the sample to confirm the issue:
select topology.DropTopology('topologia3D');
select topology.CreateTopology('topologia3D',6707, 0.000051, true);
select topology.TopoGeo_AddLineString( 'topologia3D',
GeomFromEWKT('SRID=6707;LINESTRING(618367.6099999999 4833785.16
0.88,618370 4833784.94 1.93,618370 4833780.209999999
1.92,618364.0799999999 4833780.719999999 1.18)'), 0.000051 );
GeomFromEWKT('SRID=6707;LINESTRING(618467.1999999999 4833771.82 1.9,618370
4833780.209999999 1.92,618370 4833784.94 1.93,618387.8499999999 4833783.28
1.93)'), 0.000051 );
Regards,
Andrea Peri.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3711>
