[postgis-tickets] [PostGIS] #3718: Invalid edge (no two distinct vertices exist)
trac at osgeo.org
Tue Feb 21 08:00:56 PST 2017
Reporter: Andreas | Owner: strk
Wicht |
Type: | Status: new
enhancement |
Priority: high | Milestone: PostGIS 2.3.3
Component: topology | Version: 2.3.x
Resolution: | Keywords: topology, tolerance, 0-length, edge
Comment (by strk):
you have a lot of "need upgrade" warnings in your postgis version, does it
make any difference if you fix that ? At least the topology part. If
reducing the tolerance works for you, go for it !
Line-segments with length 0 should not be a problem on their own. The
message complains about a full edge with 0 length, possibly produced by an
internal processing (hopefully changed by changing tolerance).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3718#comment:1>
