[postgis-tickets] [PostGIS] #3712: Address MVT issues reported by specification author
trac at osgeo.org
Tue Feb 21 13:30:07 PST 2017
Reporter: strk | Owner: Björn Harrtell
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by flippmoke):
@nicklas:
>If I understand things right, the problem is in validness that turns up
fro simplification and scaling.
Yes, but the original data is often invalid to begin with. This is why I
currently do the following steps:
Simplification => Scaling => Clipping => Make Valid
In order to speed up processing, I have found that for more then one tile,
Simplification and Scaling can be done once for a shape for an entire zoom
level, and you can create multiple tiles from that data. This is not ideal
for many situations though where you just want to create one.
We have found douglas-peuker to be best at actually preserving the
original shape, but your ideas sound interesting but also adding a lot
more complexity, will think about it more.
@Björn Harrtell
I have thought about all of this problem probably more then I should as
far as the validity and I have found that snap rounding is very important
in some ways to prevent intersections in odd ways. The only way I was able
to solve this was through creating https://github.com/mapbox/wagyu/. In
short it is Snap Rounding + Vatti + Additional Correction and by testing
it repeatedly with a fuzzer, I was able to make it produce OGC valid
polygon output 100% of the time -- no matter the input. It is reasonably
fast (considering all it does). If anyone here ever wants a walk through
of the algorithm and code -- I would love to do it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3712#comment:16>
