[postgis-tickets] [PostGIS] #3718: Invalid edge (no two distinct vertices exist)
trac at osgeo.org
Wed Feb 22 00:33:07 PST 2017
Reporter: andehhh | Owner: strk
Type: | Status: new
enhancement |
Priority: high | Milestone: PostGIS 2.3.3
Component: topology | Version: 2.3.x
Resolution: | Keywords: topology, tolerance, 0-length, edge
Comment (by strk):
You had it *before*, but you didn't upgrade correctly yet so please do so
before continuing with the debugging.
A 0-length edge would be an error, yes. The toTopoGeom (and the lower
level TopoGeo_addXXX) function should not allow entering such edges. You
can enable debugging to see what's *generating* that 0-length edge, if
it's not in input. Yes, the code should ideally handle this case
internally and simply skip 0-length edges.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3718#comment:3>
