[postgis-tickets] [PostGIS] #3712: Address MVT issues reported by specification author
trac at osgeo.org
Wed Feb 22 12:05:46 PST 2017
Reporter: strk | Owner: Björn Harrtell
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Björn Harrtell):
I'm now leaning towards both suggestions by @flippmoke and @strk i.e
providing a function that generates spec compliant output if not forced
otherwise and breaking apart the logic assembling the tile binary vs. the
geometry translation. I propose the following revised ST_AsMVT and a new
function ST_AsMVTGeom as follows:
{{{#!sql
-- revised ST_AsMVT function
-- assumes geometry already in MVT tile coordinate space
-- moved bounds, buffer and clip_geom to new function ST_AsMVTGeom
bytea ST_AsMVT(text name, integer extent, text geom_name, anyelement row)
-- translates a geometry to MVT tile coordinate space with optional
clipping
-- should make sure output is valid according to spec, perhaps by simply
using existing ST_MakeValid logic
geometry ST_AsMVTGeom(geometry geom, box2d bounds, integer extent, integer
buffer, boolean clip_geom)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3712#comment:22>
