[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie
PostGIS trac at osgeo.org
Mon Feb 27 00:22:26 PST 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 Just noticed this on debbie.  I'm rerunning to confirm it's still an
 issue.
  geobuf .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.6w64/test_117_diff)
 --- geobuf_expected     2017-02-26 18:37:40.110686758 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.6w64/test_117_out
 2017-02-26 18:41:54.722689185 +0000
 @@ -3,9 +3,18 @@
 dF9mbG9hdBgAIjoKOAoICAIaBAICAgJqBgoEdGVzdGoCGAFqAiABagUKAzEuMWoJEZqZmZmZmfE/
  cgoAAAEBAgIDAwQE
  T3|GAAiEAoOCgwIBBoIAAAAAgIAAAE=
 -T4|GAAiHAoaChgIBBICBAQaEAAAAAoKAAAJAgIAAgIAAAE=
 +T4|GAAirwEKrAEKqQEIBBICBAQaoAH///////////8B////////////Af///////////wH/////////
 +//8B////////////Af///////////wH///////////8B////////////Af///////////wH/////
 +//////8B////////////Af///////////wH///////////8B////////////Af///////////wH/
 +//////////8B
  T5|GAAiEAoOCgwIARoIFFA8EycTFBM=
 -T6|GAAiGgoYChYIAxICAwQaDhQUFBQTKFBQExMUExMT
 -T7|GAAiJgokCiIIBRIGAgEDAgUDGhZQUCcKMh0oRhMJACcoCR4ePCgTCQAU
 +T6|GAAimwEKmAEKlQEIAxICAwQajAH///////////8B////////////Af///////////wH/////////
 +//////8B////////////Af///////////wH///////////8B////////////AQ==
 +T7|GAAi7wEK7AEK6QEIBRIGAgEDAgUDGtwB////////////Af///////////wH///////////8B////
 +////////Af///////////wH///////////8B////////////Af///////////wH///////////8B
 +////////////Af///////////wH///////////8B////////////Af///////////wH/////////
 +//////8B////////////AQ==
  T8|GAAiGAoWChQIBiIGCAAaAggMIggIAhoECAwGCA==
  T9|EAMYACILCgkKBwgAGgMCBAY=
 Winnie has got other issues but that might be because I'm in middle of
 upgrading her GDAL among other things.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720>
