[postgis-tickets] [PostGIS] #3722: ST_ASMVT regress on PostgreSQL 10
PostGIS trac at osgeo.org
Mon Feb 27 13:08:40 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 Ok this is tricky. In the past we used two _expected files and copied the
 appropriate one based on version (was done for GEOS). Annoying because
 then you have to remember to update both when adding new tests, but
 effective.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3722#comment:3>
