[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
trac at osgeo.org
Tue Feb 28 13:44:31 PST 2017
Reporter: robe | Owner: Björn Harrtell
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by Björn Harrtell):
Installed a clean Debian Jessie (8.7.1), protobuf 3.0.2 and protobuf-c
1.2.1 then built postgis svn-trunk and ran tests. Cannot reproduce issue.
The only diff I can spot from the logs is that Debbie has GCC 5 and PG
9.6.2 but I use Jessie defaults (GCC 4.9.2 and PG 9.4.10). On my Debian
Stretch I got GCC 6.3.0 and PG 9.6.2.
We also have passing build&test at Travis and GitLab pipeline both using
slightly different systems and package versions.
I'm not sure how to proceed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:18>
