[postgis-tickets] r15484 - Commit Fuzzers for liblwgeom wkb OSS FUZZ testing
Regina Obe lr at pcorp.us
Mon Jul 10 13:06:12 PDT 2017
Author: robe
Date: 2017-07-10 13:06:12 -0700 (Mon, 10 Jul 2017)
New Revision: 15484
Added:
   trunk/fuzzers/
   trunk/fuzzers/Makefile
   trunk/fuzzers/README.TXT
   trunk/fuzzers/build_google_oss_fuzzers.sh
   trunk/fuzzers/build_seed_corpus.sh
   trunk/fuzzers/fuzzingengine.c
   trunk/fuzzers/wkb_import_fuzzer.cpp
   trunk/fuzzers/wkb_import_fuzzer.options
   trunk/fuzzers/wkt_import_fuzzer.cpp
   trunk/fuzzers/wkt_import_fuzzer.dict
   trunk/fuzzers/wkt_import_fuzzer.options
Fuzzers contributed by Even Rouault
References #3783 for PostGIS 2.4 (trunk)
Added: trunk/fuzzers/Makefile
--- trunk/fuzzers/Makefile	                        (rev 0)
+++ trunk/fuzzers/Makefile	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,10 @@
+clean:
+	$(RM) -f *.o *.a
+fuzzingengine.o: fuzzingengine.c
+	$(CC) $(CFLAGS) -c -o $@ $<
+dummyfuzzers: fuzzingengine.o
+	$(AR) r libFuzzingEngine.a fuzzingengine.o
+	CXX="${CXX}" CXXFLAGS="-L. ${CXXFLAGS}" SRC=/tmp OUT=/tmp ./build_google_oss_fuzzers.sh
+	OUT=/tmp ./build_seed_corpus.sh
Added: trunk/fuzzers/README.TXT
--- trunk/fuzzers/README.TXT	                        (rev 0)
+++ trunk/fuzzers/README.TXT	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,38 @@
+This directory contain fuzzer main functions and scripts for the
+Google OSS Fuzz project: https://github.com/google/oss-fuzz/
+The main build scripts are in:
+https://github.com/google/oss-fuzz/tree/master/projects/postgis
+and call scripts in this directory.
+The list of issues is in:
+https://bugs.chromium.org/p/oss-fuzz/issues/list?q=postgis
+- Simulate the build of (dummy) fuzzers like OSS Fuzz does:
+    $ make dummyfuzzers
+  They are created in /tmp/*_fuzzer as well as with the
+  /tmp/*_fuzzer_seed_corpus.zip files
+  Run one:
+    $ /tmp/wkt_import_fuzzer a_file_name
+- Run locally OSS Fuzz:
+    $ git clone https://github.com/google/oss-fuzz.git
+    $ cd oss-fuzz
+    $ python infra/helper.py build_image postgis
+  Build fuzzers with the address sanitizer (could use undefined, etc...)
+    $ python infra/helper.py build_fuzzers --sanitizer address postgis
+  Test a particular fuzzer (replace wkt_import_fuzzer by other fuzzers
+  like the ones generated in /tmp by "make dummyfuzzers")
+    $ python infra/helper.py run_fuzzer postgis wkt_import_fuzzer
+How to deal with issues reported in https://bugs.chromium.org/p/oss-fuzz/issues/list?q=postgis ?
+    1. Leave a comment in (chromium database) bug entry to indicate that you work on it
+    2. Work
+    3. Commit a bug fix with log including "Credit to OSS-Fuzz" and a link to the bugs.chromium.org ticket
+    4. Add in the bugs.chromium.org ticket a link to the Trac changeset implementing the fix.
+    5. Check chromium closed the bug (after one or two days typically)
Added: trunk/fuzzers/build_google_oss_fuzzers.sh
--- trunk/fuzzers/build_google_oss_fuzzers.sh	                        (rev 0)
+++ trunk/fuzzers/build_google_oss_fuzzers.sh	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,40 @@
+#!/bin/bash
+set -e
+if [ "$SRC" == "" ]; then
+    echo "SRC env var not defined"
+    exit 1
+fi
+if [ "$OUT" == "" ]; then
+    echo "OUT env var not defined"
+    exit 1
+fi
+if [ "$CXX" == "" ]; then
+    echo "CXX env var not defined"
+    exit 1
+fi
+SRC_DIR=$(dirname $0)/..
+build_fuzzer()
+    fuzzerName=$1
+    sourceFilename=$2
+    shift
+    shift
+    echo "Building fuzzer $fuzzerName"
+    $CXX $CXXFLAGS -std=c++11 -I$SRC_DIR/liblwgeom \
+        $sourceFilename $* -o $OUT/$fuzzerName \
+        -lFuzzingEngine -lstdc++ $SRC_DIR/liblwgeom/.libs/liblwgeom.a
+fuzzerFiles=$(dirname $0)/*.cpp
+for F in $fuzzerFiles; do
+    fuzzerName=$(basename $F .cpp)
+    build_fuzzer $fuzzerName $F
+done
+cp $(dirname $0)/*.dict $(dirname $0)/*.options $OUT/
\ No newline at end of file
Added: trunk/fuzzers/build_seed_corpus.sh
--- trunk/fuzzers/build_seed_corpus.sh	                        (rev 0)
+++ trunk/fuzzers/build_seed_corpus.sh	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,10 @@
+#!/bin/bash
+set -e
+    exit 1
+fi
+# Nothing for now
Added: trunk/fuzzers/fuzzingengine.c
--- trunk/fuzzers/fuzzingengine.c	                        (rev 0)
+++ trunk/fuzzers/fuzzingengine.c	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,69 @@
+ * Project:  GDAL
+ * Purpose:  Fuzzer
+ * Author:   Even Rouault, even.rouault at spatialys.com
+ * Copyright (c) 2017, Even Rouault <even.rouault at spatialys.com>
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include <stdlib.h>
+#include <stdio.h>
+int LLVMFuzzerTestOneInput(void *buf, size_t len);
+int LLVMFuzzerInitialize(int* argc, char*** argv);
+int main(int argc, char* argv[])
+    LLVMFuzzerInitialize(&argc, &argv);
+    if( argc < 2 )
+        return LLVMFuzzerTestOneInput(" ", 1);
+    else
+        int nRet = 0;
+        void* buf = NULL;
+        int nLen = 0;
+        FILE* f = fopen(argv[1], "rb");
+        if( !f )
+            fprintf(stderr, "%s does not exist.\n", argv[1]);
+            exit(1);
+        fseek(f, 0, SEEK_END);
+        nLen = (int)ftell(f);
+        fseek(f, 0, SEEK_SET);
+        buf = malloc(nLen);
+        if( !buf )
+            fprintf(stderr, "malloc failed.\n");
+            fclose(f);
+            exit(1);
+        fread(buf, nLen, 1, f);
+        fclose(f);
+        nRet = LLVMFuzzerTestOneInput(buf, nLen);
+        free(buf);
+        return nRet;
Added: trunk/fuzzers/wkb_import_fuzzer.cpp
--- trunk/fuzzers/wkb_import_fuzzer.cpp	                        (rev 0)
+++ trunk/fuzzers/wkb_import_fuzzer.cpp	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,199 @@
+ * Project:  PostGIS
+ * Purpose:  Fuzzer
+#include <assert.h>
+#include <stddef.h>
+#include <stdint.h>
+#include <string.h>
+#include <setjmp.h>
+#include <set>
+extern "C"
+#include "liblwgeom.h"
+void GEOSCoordSeq_destroy() { assert(0); }
+void GEOSClipByRect() { assert(0); }
+void GEOSUnion() { assert(0); }
+void GEOSCoordSeq_getDimensions() { assert(0); }
+void GEOSPreparedCovers() { assert(0); }
+void GEOSPreparedContains() { assert(0); }
+void GEOSSymDifference() { assert(0); }
+void GEOSUnionCascaded() { assert(0); }
+void GEOSGetExteriorRing() { assert(0); }
+void GEOSCoordSeq_setX() { assert(0); }
+void GEOSGeom_createLineString() { assert(0); }
+void GEOSCoordSeq_getY() { assert(0); }
+void GEOSEquals() { assert(0); }
+void GEOSRelatePatternMatch() { assert(0); }
+void GEOSGeom_createCollection() { assert(0); }
+void GEOSGeom_extractUniquePoints() { assert(0); }
+void GEOSNormalize() { assert(0); }
+void GEOSVoronoiDiagram() { assert(0); }
+void GEOSArea() { assert(0); }
+void GEOSLineMerge() { assert(0); }
+void GEOSGeom_createPolygon() { assert(0); }
+void GEOSGetCentroid() { assert(0); }
+void GEOSCoordSeq_create() { assert(0); }
+void GEOSFree() { assert(0); }
+void initGEOS() { assert(0); }
+void GEOSIntersection() { assert(0); }
+void GEOSEnvelope() { assert(0); }
+void GEOSGetGeometryN() { assert(0); }
+void GEOSSTRtree_insert() { assert(0); }
+void GEOSGeomTypeId() { assert(0); }
+void GEOSBoundary() { assert(0); }
+void GEOSversion() { assert(0); }
+void GEOSGetInteriorRingN() { assert(0); }
+void GEOSCoordSeq_setY() { assert(0); }
+void GEOSGetSRID() { assert(0); }
+void GEOSGeom_destroy() { assert(0); }
+void GEOSGeom_createEmptyPolygon() { assert(0); }
+void GEOSPolygonize() { assert(0); }
+void GEOSCoordSeq_getX() { assert(0); }
+void GEOSSharedPaths() { assert(0); }
+void GEOSSTRtree_create() { assert(0); }
+void GEOSGeom_clone() { assert(0); }
+void GEOSRelateBoundaryNodeRule() { assert(0); }
+void GEOSSnap() { assert(0); }
+void GEOSRelatePattern() { assert(0); }
+void GEOSSetSRID() { assert(0); }
+void GEOSisValid() { assert(0); }
+void GEOSContains() { assert(0); }
+void GEOSPreparedGeom_destroy() { assert(0); }
+void GEOSCoordSeq_setZ() { assert(0); }
+void GEOSOffsetCurve() { assert(0); }
+void GEOSUnaryUnion() { assert(0); }
+void GEOSPrepare() { assert(0); }
+void GEOSCoordSeq_getSize() { assert(0); }
+void GEOSGetNumInteriorRings() { assert(0); }
+void GEOSGetNumGeometries() { assert(0); }
+void GEOSisSimple() { assert(0); }
+void GEOSDifference() { assert(0); }
+void GEOSPreparedIntersects() { assert(0); }
+void GEOSisEmpty() { assert(0); }
+void GEOSPointOnSurface() { assert(0); }
+void GEOSSTRtree_query() { assert(0); }
+void GEOSGeom_createPoint() { assert(0); }
+void GEOSSTRtree_destroy() { assert(0); }
+void GEOSIntersects() { assert(0); }
+void GEOSHasZ() { assert(0); }
+void GEOSGeom_getCoordSeq() { assert(0); }
+void GEOSCoordSeq_getZ() { assert(0); }
+void GEOSGeom_createLinearRing() { assert(0); }
+void GEOSGeomType() { assert(0); }
+void GEOSDelaunayTriangulation() { assert(0); }
+void geod_init() { assert(0); }
+void geod_inverse() { assert(0); }
+void geod_direct() { assert(0); }
+void geod_polygon_init() { assert(0); }
+void geod_polygon_addpoint() { assert(0); }
+void geod_polygon_compute() { assert(0); }
+extern "C" int LLVMFuzzerInitialize(int* argc, char*** argv);
+// Keep active heap allocated memory corresponding to returns of allocator()
+// and reallocator()
+std::set<void*> oSetPointers;
+jmp_buf jmpBuf;
+extern "C"
+    static void *
+    allocator(size_t size)
+            void *mem = malloc(size);
+            oSetPointers.insert(mem);
+            return mem;
+    static void
+    freeor(void *mem)
+            oSetPointers.erase(mem);
+            free(mem);
+    static void *
+    reallocator(void *mem, size_t size)
+            void *ret = realloc(mem, size);
+            oSetPointers.insert(ret);
+            return ret;
+    static void
+    noticereporter(const char *, va_list )
+    static void
+    errorreporter(const char *, va_list )
+        // Cleanup any heap-allocated memory still active
+        for(std::set<void*>::iterator oIter = oSetPointers.begin();
+            oIter != oSetPointers.end(); ++oIter )
+            free(*oIter);
+        oSetPointers.clear();
+        // Abort everything to jump to setjmp() call
+        longjmp(jmpBuf, 1);
+    static void
+    debuglogger(int, const char *, va_list)
+int LLVMFuzzerInitialize(int* /*argc*/, char*** /*argv*/)
+    lwgeom_set_handlers(allocator, reallocator, freeor, errorreporter, noticereporter);
+    lwgeom_set_debuglogger(debuglogger);
+    return 0;
+extern "C" int LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len);
+int LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len)
+    if( setjmp(jmpBuf) )
+        return 0;
+    LWGEOM* lwgeom = lwgeom_from_wkb(buf, len, LW_PARSER_CHECK_NONE);
+    lwgeom_free(lwgeom);
+    //assert( oSetPointers.empty() );
+    return 0;
Added: trunk/fuzzers/wkb_import_fuzzer.options
--- trunk/fuzzers/wkb_import_fuzzer.options	                        (rev 0)
+++ trunk/fuzzers/wkb_import_fuzzer.options	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,2 @@
+[libfuzzer]
+max_len = 100000
Added: trunk/fuzzers/wkt_import_fuzzer.cpp
--- trunk/fuzzers/wkt_import_fuzzer.cpp	                        (rev 0)
+++ trunk/fuzzers/wkt_import_fuzzer.cpp	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,204 @@
+ * Purpose:  Fuzzer
+#include <set>
+extern "C"
+jmp_buf jmpBuf;
+extern "C"
+    static void *
+            return mem;
+    static void
+    freeor(void *mem)
+            free(mem);
+    static void *
+            return ret;
+    static void
+    static void
+            free(*oIter);
+    static void
+    return 0;
+    char* pszWKT = static_cast<char*>(malloc( len + 1 ));
+    memcpy(pszWKT, buf, len);
+    pszWKT[len] = '\0';
+    if( !setjmp(jmpBuf) )
+        LWGEOM* lwgeom = lwgeom_from_wkt(pszWKT, LW_PARSER_CHECK_NONE);
+    free(pszWKT);
+    return 0;
Added: trunk/fuzzers/wkt_import_fuzzer.dict
--- trunk/fuzzers/wkt_import_fuzzer.dict	                        (rev 0)
+++ trunk/fuzzers/wkt_import_fuzzer.dict	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,25 @@
+0 0
+0 0 0
+0 0 0 0
+POINT
+LINESTRING
+POLYGON
+MULTIPOINT
+MULTILINESTRING
+MULTIPOLYGON
+GEOMETRYCOLLECTION
+CURVEPOLYGON
+CIRCULARSTRING
+COMPOUNDCURVE
+MULTICURVE
+MULTISURFACE
+TIN
+TRIANGLE
+POLYHEDRALSURFACE
+EMPTY
+space=" "
+Z
+M
Added: trunk/fuzzers/wkt_import_fuzzer.options
--- trunk/fuzzers/wkt_import_fuzzer.options	                        (rev 0)
+++ trunk/fuzzers/wkt_import_fuzzer.options	2017-07-10 20:06:12 UTC (rev 15484)
@@ -0,0 +1,2 @@
+[libfuzzer]
+max_len = 100000
