[postgis-tickets] [PostGIS] #3787: Wrong results when using 3D in topology
trac at osgeo.org
Fri Jul 14 05:46:40 PDT 2017
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.3.x
Keywords: |
Hi, working with us rt_topology suite we discovered an issue on the
topology. Other test show that the issue is alsoin postgis .
I try the test on postgis 2.3.2.
On postgis 2.3.2:
I try this little sql:
select topology.droptopology('topo_test');
select topology.createtopology('topo_test', 6707, 0.0145,true);
select topology.TopoGeo_AddLineString( 'topo_test' , GeomFromEWKT(
'SRID=6707;LineString(0 0 0, 100 0 0)'), 0.0145 );
'SRID=6707;LineString(50 -50 0.001, 50 50 0.001)') , 0.0145 );
The result retrieved using
select ST_Astext(geom) from topo_test.edge_data;
Is
LINESTRING Z(0 0 0, 50 0 0) LINESTRING Z(50 0 0, 100 0 0) LINESTRING Z(50
-50 0.001, 50 0 0.0005) LINESTRING Z(50 0 0.0005, 50 50 0.001)
Istead if I try the same noding using the usual ST_NOde function:
The result I have is this other:
ST_AsText(
ST_Node(
ST_Collect(
GeomFromEWKT( 'SRID=6707;MultiLineString((0 0 0, 100 0 0))'),
GeomFromEWKT( 'SRID=6707;MultiLineString((50 -50 0.001, 50 50
0.001))')
(0 0 0, 50 0 0.0005), (50 -50 0.001, 50 0 0.0005), (50 0 0.0005, 100 0 0),
I open a ticket also in the rt_topology issue system:
https://git.osgeo.org/gogs/rttopo/librttopo/issues/26
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3787>
