[postgis-tickets] r15490 - Back port all changes since Jan 2016.
Regina Obe lr at pcorp.us
Thu Jul 20 15:48:06 PDT 2017
Author: robe
Date: 2017-07-20 15:48:06 -0700 (Thu, 20 Jul 2017)
New Revision: 15490
   branches/2.2/NEWS
   branches/2.2/liblwgeom/ptarray.c
References #3768 OSS Fuzz fixes
Correction of strk's email
formatting cleanup by strk
and adjustments to logic for readability by strk
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2017-07-20 22:34:53 UTC (rev 15489)
+++ branches/2.2/NEWS	2017-07-20 22:48:06 UTC (rev 15490)
@@ -1,3 +1,9 @@
+PostGIS 2.2.6
+2017/xx/xx
+ * Bug Fixes *
+  - #3786, ptarray null and heap issues on is_closed
 PostGIS 2.2.5
 2017/01/29
Modified: branches/2.2/liblwgeom/ptarray.c
--- branches/2.2/liblwgeom/ptarray.c	2017-07-20 22:34:53 UTC (rev 15489)
+++ branches/2.2/liblwgeom/ptarray.c	2017-07-20 22:48:06 UTC (rev 15490)
@@ -3,14 +3,27 @@
  * PostGIS - Spatial Types for PostgreSQL
  * http://postgis.net
- * Copyright (C) 2012 Sandro Santilli <strk at keybit.net>
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright (C) 2012 Sandro Santilli <strk at kbt.io>
  * Copyright (C) 2001-2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU General Public Licence. See the COPYING file.
 #include <stdio.h>
 #include <string.h>
@@ -58,25 +71,25 @@
 	POINTARRAY *pa = lwalloc(sizeof(POINTARRAY));
 	pa->serialized_pointlist = NULL;
 	/* Set our dimsionality info on the bitmap */
 	pa->flags = gflags(hasz, hasm, 0);
 	/* We will be allocating a bit of room */
 	pa->npoints = 0;
 	pa->maxpoints = maxpoints;
 	/* Allocate the coordinate array */
 	if ( maxpoints > 0 )
 		pa->serialized_pointlist = lwalloc(maxpoints * ptarray_point_size(pa));
-	else
+	else
 	return pa;
-* Add a point into a pointarray. Only adds as many dimensions as the
+* Add a point into a pointarray. Only adds as many dimensions as the
 * pointarray supports.
 int
@@ -85,22 +98,22 @@
 	size_t point_size = ptarray_point_size(pa);
 	LWDEBUGF(5,"pa = %p; p = %p; where = %d", pa, p, where);
 	LWDEBUGF(5,"pa->npoints = %d; pa->maxpoints = %d", pa->npoints, pa->maxpoints);
-	if ( FLAGS_GET_READONLY(pa->flags) )
+	if ( FLAGS_GET_READONLY(pa->flags) )
 		lwerror("ptarray_insert_point: called on read-only point array");
 		return LW_FAILURE;
 	/* Error on invalid offset value */
 	if ( where > pa->npoints || where < 0)
 		lwerror("ptarray_insert_point: offset out of range (%d)", where);
 		return LW_FAILURE;
 	/* If we have no storage, let's allocate some */
-	if( pa->maxpoints == 0 || ! pa->serialized_pointlist )
+	if( pa->maxpoints == 0 || ! pa->serialized_pointlist )
 		pa->maxpoints = 32;
 		pa->npoints = 0;
@@ -113,14 +126,14 @@
 		lwerror("npoints (%d) is greated than maxpoints (%d)", pa->npoints, pa->maxpoints);
 		return LW_FAILURE;
 	/* Check if we have enough storage, add more if necessary */
 	if( pa->npoints == pa->maxpoints )
 		pa->maxpoints *= 2;
 		pa->serialized_pointlist = lwrealloc(pa->serialized_pointlist, ptarray_point_size(pa) * pa->maxpoints);
 	/* Make space to insert the new point */
 	if( where < pa->npoints )
@@ -128,14 +141,14 @@
 		memmove(getPoint_internal(pa, where+1), getPoint_internal(pa, where), copy_size);
 		LWDEBUGF(5,"copying %d bytes to start vertex %d from start vertex %d", copy_size, where+1, where);
 	/* We have one more point */
 	++pa->npoints;
 	/* Copy the new point into the gap */
 	ptarray_set_point4d(pa, where, p);
 	LWDEBUGF(5,"copying new point to start vertex %d", point_size, where);
 	return LW_SUCCESS;
@@ -144,7 +157,7 @@
 	/* Check for pathology */
-	if( ! pa || ! pt )
+	if( ! pa || ! pt )
 		lwerror("ptarray_append_point: null input");
 		return LW_FAILURE;
@@ -179,14 +192,14 @@
 	unsigned int ptsize;
-	if( ! pa1 || ! pa2 )
+	if( ! pa1 || ! pa2 )
 		lwerror("ptarray_append_ptarray: null input");
 		return LW_FAILURE;
 	npoints = pa2->npoints;
 	if ( ! npoints ) return LW_SUCCESS; /* nothing more to do */
 	if( FLAGS_GET_READONLY(pa1->flags) )
@@ -216,11 +229,11 @@
 			--npoints;
 		else if ( gap_tolerance == 0 || ( gap_tolerance > 0 &&
-		           distance2d_pt_pt(&tmp1, &tmp2) > gap_tolerance ) )
+		           distance2d_pt_pt(&tmp1, &tmp2) > gap_tolerance ) )
 			lwerror("Second line start point too far from first line end point");
 			return LW_FAILURE;
 	/* Check if we need extra space */
@@ -241,7 +254,7 @@
 int
@@ -250,33 +263,33 @@
 	size_t ptsize = ptarray_point_size(pa);
-	if( ! pa )
+	if( ! pa )
 		lwerror("ptarray_remove_point: null input");
 		return LW_FAILURE;
 	if ( where >= pa->npoints || where < 0)
 		lwerror("ptarray_remove_point: offset out of range (%d)", where);
 		return LW_FAILURE;
 	/* If the point is any but the last, we need to copy the data back one point */
 	if( where < pa->npoints - 1 )
 		memmove(getPoint_internal(pa, where), getPoint_internal(pa, where+1), ptsize * (pa->npoints - where - 1));
 	/* We have one less point */
 	pa->npoints--;
 	return LW_SUCCESS;
-* Build a new #POINTARRAY, but on top of someone else's ordinate array.
+* Build a new #POINTARRAY, but on top of someone else's ordinate array.
 * Flag as read-only, so that ptarray_free() does not free the serialized_ptlist
 POINTARRAY* ptarray_construct_reference_data(char hasz, char hasm, uint32_t npoints, uint8_t *ptlist)
@@ -319,7 +332,7 @@
 	if(pa)
 		if(pa->serialized_pointlist && ( ! FLAGS_GET_READONLY(pa->flags) ) )
-			lwfree(pa->serialized_pointlist);
+			lwfree(pa->serialized_pointlist);
 		lwfree(pa);
 		LWDEBUG(5,"Freeing a PointArray");
@@ -418,7 +431,7 @@
 	/* Initial storage */
 	opa = ptarray_construct_empty(hasz, hasm, ipa->npoints);
 	/* Add first point */
 	getPoint4d_p(ipa, ipoff, &p1);
 	ptarray_append_point(opa, &p1, LW_FALSE);
@@ -447,7 +460,7 @@
 			pbuf.x = p1.x + (p2.x-p1.x)/segdist * dist;
 			pbuf.y = p1.y + (p2.y-p1.y)/segdist * dist;
-			if( hasz )
+			if( hasz )
 				pbuf.z = p1.z + (p2.z-p1.z)/segdist * dist;
 			if( hasm )
 				pbuf.m = p1.m + (p2.m-p1.m)/segdist * dist;
@@ -475,7 +488,7 @@
 	if ( FLAGS_GET_ZM(pa1->flags) != FLAGS_GET_ZM(pa2->flags) ) return LW_FALSE;
 	LWDEBUG(5,"dimensions are the same");
 	if ( pa1->npoints != pa2->npoints ) return LW_FALSE;
 	LWDEBUG(5,"npoints are the same");
@@ -660,12 +673,19 @@
-* Check for ring closure using whatever dimensionality is declared on the
+* Check for ring closure using whatever dimensionality is declared on the
 * pointarray.
 int
 ptarray_is_closed(const POINTARRAY *in)
+	if (!in)
+		lwerror("ptarray_is_closed: called with null point array");
+		return 0;
+	if (in->npoints <= 1 ) return in->npoints; /* single-point are closed, empty not closed */
 	return 0 == memcmp(getPoint_internal(in, 0), getPoint_internal(in, in->npoints-1), ptarray_point_size(in));
@@ -673,13 +693,27 @@
 int
 ptarray_is_closed_2d(const POINTARRAY *in)
-	return 0 == memcmp(getPoint_internal(in, 0), getPoint_internal(in, in->npoints-1), sizeof(POINT2D));
+	if (!in)
+		lwerror("ptarray_is_closed_2d: called with null point array");
+		return 0;
+	return 0 == memcmp(getPoint_internal(in, 0), getPoint_internal(in, in->npoints-1), sizeof(POINT2D) );
 int
 ptarray_is_closed_3d(const POINTARRAY *in)
-	return 0 == memcmp(getPoint_internal(in, 0), getPoint_internal(in, in->npoints-1), sizeof(POINT3D));
+	if (!in)
+		lwerror("ptarray_is_closed_3d: called with null point array");
+		return 0;
+	return 0 == memcmp(getPoint_internal(in, 0), getPoint_internal(in, in->npoints-1), sizeof(POINT3D) );
 int
@@ -695,13 +729,13 @@
 * Return 1 if the point is inside the POINTARRAY, -1 if it is outside,
 * and 0 if it is on the boundary.
-int
+int
 ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
 	return ptarray_contains_point_partial(pa, pt, LW_TRUE, NULL);
-int
+int
 ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number)
 	int wn = 0;
@@ -715,23 +749,23 @@
 	seg2 = getPoint2d_cp(pa, pa->npoints-1);
 	if ( check_closed && ! p2d_same(seg1, seg2) )
 		lwerror("ptarray_contains_point called on unclosed ring");
 	for ( i=1; i < pa->npoints; i++ )
 		seg2 = getPoint2d_cp(pa, i);
 		/* Zero length segments are ignored. */
 		if ( seg1->x == seg2->x && seg1->y == seg2->y )
 			seg1 = seg2;
 			continue;
 		ymin = FP_MIN(seg1->y, seg2->y);
 		ymax = FP_MAX(seg1->y, seg2->y);
 		/* Only test segments in our vertical range */
-		if ( pt->y > ymax || pt->y < ymin )
+		if ( pt->y > ymax || pt->y < ymin )
 			seg1 = seg2;
 			continue;
@@ -739,9 +773,9 @@
 		side = lw_segment_side(seg1, seg2, pt);
-		* A point on the boundary of a ring is not contained.
-		* WAS: if (fabs(side) < 1e-12), see #852
+		* A point on the boundary of a ring is not contained.
+		* WAS: if (fabs(side) < 1e-12), see #852
 		if ( (side == 0) && lw_pt_in_seg(pt, seg1, seg2) )
@@ -757,7 +791,7 @@
 			wn++;
 		* If the point is to the right of the line, and it's falling,
 		* then the line is to the right of the point and circling
@@ -767,7 +801,7 @@
 			wn--;
 		seg1 = seg2;
@@ -780,7 +814,7 @@
 		return LW_OUTSIDE;
 	/* Inside */
 	return LW_INSIDE;
@@ -794,13 +828,13 @@
-int
+int
 ptarrayarc_contains_point(const POINTARRAY *pa, const POINT2D *pt)
 	return ptarrayarc_contains_point_partial(pa, pt, LW_TRUE /* Check closed*/, NULL);
-int
+int
 ptarrayarc_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number)
 	int wn = 0;
@@ -831,28 +865,28 @@
 		lwerror("ptarrayarc_contains_point called on unclosed ring");
 		return LW_OUTSIDE;
 	/* OK, it's closed. Is it just one circle? */
 	else if ( p2d_same(seg1, seg3) && pa->npoints == 3 )
 		double radius, d;
 		POINT2D c;
 		seg2 = getPoint2d_cp(pa, 1);
 		/* Wait, it's just a point, so it can't contain anything */
 		if ( lw_arc_is_pt(seg1, seg2, seg3) )
 			return LW_OUTSIDE;
 		/* See if the point is within the circle radius */
 		radius = lw_arc_center(seg1, seg2, seg3, &c);
 		d = distance2d_pt_pt(pt, &c);
 		if ( FP_EQUALS(d, radius) )
 			return LW_BOUNDARY; /* Boundary of circle */
-		else if ( d < radius )
+		else if ( d < radius )
 			return LW_INSIDE; /* Inside circle */
-		else
+		else
 			return LW_OUTSIDE; /* Outside circle */
 	else if ( p2d_same(seg1, pt) || p2d_same(seg3, pt) )
 		return LW_BOUNDARY; /* Boundary case */
@@ -864,42 +898,42 @@
 		seg3 = getPoint2d_cp(pa, i+1);
 		/* Catch an easy boundary case */
 		if( p2d_same(seg3, pt) )
 			return LW_BOUNDARY;
 		/* Skip arcs that have no size */
 			seg1 = seg3;
 			continue;
 		lw_arc_calculate_gbox_cartesian_2d(seg1, seg2, seg3, &gbox);
-		if ( pt->y > gbox.ymax || pt->y < gbox.ymin )
+		if ( pt->y > gbox.ymax || pt->y < gbox.ymin )
 			seg1 = seg3;
 			continue;
 		/* Outside of horizontal range, and not between end points we also skip */
-		if ( (pt->x > gbox.xmax || pt->x < gbox.xmin) &&
-			 (pt->y > FP_MAX(seg1->y, seg3->y) || pt->y < FP_MIN(seg1->y, seg3->y)) )
+		if ( (pt->x > gbox.xmax || pt->x < gbox.xmin) &&
+			 (pt->y > FP_MAX(seg1->y, seg3->y) || pt->y < FP_MIN(seg1->y, seg3->y)) )
 			seg1 = seg3;
 			continue;
 		side = lw_arc_side(seg1, seg2, seg3, pt);
 		/* On the boundary */
 		if ( (side == 0) && lw_pt_in_arc(pt, seg1, seg2, seg3) )
 			return LW_BOUNDARY;
 		/* Going "up"! Point to left of arc. */
 		if ( side < 0 && (seg1->y <= pt->y) && (pt->y < seg3->y) )
@@ -911,9 +945,9 @@
 			wn--;
 		/* Inside the arc! */
-		if ( pt->x <= gbox.xmax && pt->x >= gbox.xmin )
+		if ( pt->x <= gbox.xmax && pt->x >= gbox.xmin )
 			POINT2D C;
 			double radius = lw_arc_center(seg1, seg2, seg3, &C);
@@ -922,7 +956,7 @@
 			/* On the boundary! */
 			if ( d == radius )
 				return LW_BOUNDARY;
 			/* Within the arc! */
 			if ( d  < radius )
@@ -930,7 +964,7 @@
 				if ( side < 0 )
 					wn++;
 				/* Right side, decrement winding number */
-				if ( side > 0 )
+				if ( side > 0 )
 					wn--;
@@ -947,13 +981,13 @@
 		return LW_OUTSIDE;
 	/* Inside */
 	return LW_INSIDE;
-* Returns the area in cartesian units. Area is negative if ring is oriented CCW,
+* Returns the area in cartesian units. Area is negative if ring is oriented CCW,
 * positive if it is oriented CW and zero if the ring is degenerate or flat.
 * http://en.wikipedia.org/wiki/Shoelace_formula
@@ -966,26 +1000,26 @@
 	double sum = 0.0;
 	double x0, x, y1, y2;
 	int i;
 	if (! pa || pa->npoints < 3 )
 		return 0.0;
 	P1 = getPoint2d_cp(pa, 0);
 	P2 = getPoint2d_cp(pa, 1);
 	x0 = P1->x;
-	for ( i = 1; i < pa->npoints - 1; i++ )
+	for ( i = 2; i < pa->npoints; i++ )
-		P3 = getPoint2d_cp(pa, i+1);
+		P3 = getPoint2d_cp(pa, i);
 		x = P2->x - x0;
 		y1 = P3->y;
 		y2 = P1->y;
 		sum += x * (y2-y1);
 		/* Move forwards! */
 		P1 = P2;
 		P2 = P3;
-	return sum / 2.0;
+	return sum / 2.0;
 int
@@ -1006,7 +1040,7 @@
 	int in_hasm = FLAGS_GET_M(pa->flags);
 	POINT4D pt;
 	POINTARRAY *pa_out = ptarray_construct_empty(hasz, hasm, pa->npoints);
 	for( i = 0; i < pa->npoints; i++ )
 		getPoint4d_p(pa, i, &pt);
@@ -1015,7 +1049,7 @@
 		if( hasm && ! in_hasm )
 			pt.m = 0.0;
 		ptarray_append_point(pa_out, &pt, LW_TRUE);
 	return pa_out;
@@ -1278,11 +1312,11 @@
 	/* Initialize our 2D copy of the input parameter */
 	p.x = p4d->x;
 	p.y = p4d->y;
 	if ( ! proj4d ) proj4d = &projtmp;
 	start = getPoint2d_cp(pa, 0);
 	/* If the pointarray has only one point, the nearest point is */
 	/* just that point */
 	if ( pa->npoints == 1 )
@@ -1292,7 +1326,7 @@
 			*mindistout = distance2d_pt_pt(&p, start);
 		return 0.0;
 	/* Loop through pointarray looking for nearest segment */
 	for (t=1; t<pa->npoints; t++)
@@ -1327,7 +1361,7 @@
 	getPoint4d_p(pa, seg, &start4d);
 	getPoint4d_p(pa, seg+1, &end4d);
 	closest_point_on_segment(p4d, &start4d, &end4d, proj4d);
 	/* Copy 4D values into 2D holder */
 	proj.x = proj4d->x;
 	proj.y = proj4d->y;
@@ -1400,7 +1434,7 @@
 POINTARRAY *
-ptarray_remove_repeated_points_minpoints(POINTARRAY *in, double tolerance, int minpoints)
+ptarray_remove_repeated_points_minpoints(const POINTARRAY *in, double tolerance, int minpoints)
 	POINTARRAY* out;
 	size_t ptsize;
@@ -1462,7 +1496,7 @@
 POINTARRAY *
-ptarray_remove_repeated_points(POINTARRAY *in, double tolerance)
+ptarray_remove_repeated_points(const POINTARRAY *in, double tolerance)
 	return ptarray_remove_repeated_points_minpoints(in, tolerance, 2);
@@ -1561,7 +1595,7 @@
 			getPoint4d_p(inpts, stack[sp], &pt);
 			LWDEBUGF(4, "npoints , minpoints %d %d", outpts->npoints, minpts);
 			ptarray_append_point(outpts, &pt, LW_FALSE);
 			LWDEBUGF(4, "Added P%d to simplified point array (size: %d)", stack[sp], outpts->npoints);
 			p1 = stack[sp--];
@@ -1591,9 +1625,9 @@
 	if ( pts->npoints % 2 != 1 )
         lwerror("arc point array with even number of points");
 	a1 = getPoint2d_cp(pts, 0);
 	for ( i=2; i < pts->npoints; i += 2 )
     	a2 = getPoint2d_cp(pts, i-1);
@@ -1618,14 +1652,14 @@
 	if ( pts->npoints < 2 ) return 0.0;
 	frm = getPoint2d_cp(pts, 0);
 	for ( i=1; i < pts->npoints; i++ )
 		to = getPoint2d_cp(pts, i);
 		dist += sqrt( ((frm->x - to->x)*(frm->x - to->x))  +
 		              ((frm->y - to->y)*(frm->y - to->y)) );
 		frm = to;
 	return dist;
@@ -1680,10 +1714,10 @@
 		lwerror("getPoint got NULL pointarray");
 		return NULL;
 	LWDEBUGF(5, "(n=%d, pa.npoints=%d, pa.maxpoints=%d)",n,pa->npoints,pa->maxpoints);
-	if ( ( n < 0 ) ||
+	if ( ( n < 0 ) ||
 	     ( n > pa->npoints ) ||
 	     ( n >= pa->maxpoints ) )
@@ -1693,7 +1727,7 @@
 #endif
 	ptr = pa->serialized_pointlist + size * n;
 	if ( FLAGS_NDIMS(pa->flags) == 2)
@@ -1739,7 +1773,7 @@
 			p4d.z = a->gfac * x + a->hfac * y + a->ifac * z + a->zoff;
 			ptarray_set_point4d(pa, i, &p4d);
-			LWDEBUGF(3, " POINT %g %g %g => %g %g %g", x, y, x, p4d.x, p4d.y, p4d.z);
+			LWDEBUGF(3, " POINT %g %g %g => %g %g %g", x, y, z, p4d.x, p4d.y, p4d.z);
 	else
@@ -1755,7 +1789,7 @@
 			p4d.y = a->dfac * x + a->efac * y + a->yoff;
+			LWDEBUGF(3, " POINT %g %g => %g %g", x, y, p4d.x, p4d.y);
@@ -1844,7 +1878,7 @@
 	return dpa;
-int
+int
 ptarray_npoints_in_rect(const POINTARRAY *pa, const GBOX *gbox)
 	const POINT2D *pt;
