[postgis-tickets] [PostGIS] #3794: debbie pdf build is brokeon
PostGIS trac at osgeo.org
Sun Jul 23 12:15:52 PDT 2017
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 2.3.4
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:
Comment (by robe):
 okay think I figured out second issue.  Perhaps the dblatex is more
 stringent.
 I discovered where it's complaining is because the auto-generated
 postgis_agg_mml.xml at least for pt_BR has empty itemizedlist of changes
 for each NEW section. I could resolve by setting the .xsl to skip
 outputting the list if no items matched.
 More pressing issue, I suspect is they translated the phrases I'm looking
 for so no longer matches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3794#comment:2>
