[postgis-tickets] [PostGIS] #3601: Translation Backrolled
trac at osgeo.org
Thu Jul 27 12:39:03 PDT 2017
Reporter: ruvyn | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: documentation | Version: trunk
Resolution: | Keywords: PostGIS 2.3.0dev Manual
Changes (by robe):
* cc: jangbi882, ruvyn (added)
Comment:
Is this still an issue or can we close out. I think I took care of most
of the issues in ko_KR that have caused recent html build failures.
I do have one glaring one with reference_output.xml (but I think that
might be with all because of the introduction of ST_AsMVT messed up the
merge numbers).
Anyway recently build Korean html is here: http://postgis.net/docs/manual-
dev/postgis-ko_KR.html
I'm still struggling with building of the PDF to understand asian
characters. If BJ Jang has some suggestions on that, that would be great.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3601#comment:11>
