[postgis-tickets] r15514 - Mark 3D functions and some other missed functions as parallel safe.
Regina Obe lr at pcorp.us
Thu Jul 27 21:09:54 PDT 2017
Author: robe
Date: 2017-07-27 21:09:54 -0700 (Thu, 27 Jul 2017)
New Revision: 15514
   branches/2.3/NEWS
   branches/2.3/doc/xsl/postgis_aggs_mm.xml.xsl
   branches/2.3/postgis/postgis.sql.in
   branches/2.3/postgis/sfcgal.sql.in
Closes #3792 for PostGIS 2.3.4
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2017-07-28 04:06:12 UTC (rev 15513)
+++ branches/2.3/NEWS	2017-07-28 04:09:54 UTC (rev 15514)
@@ -1,13 +1,14 @@
 PostGIS 2.3.4
 2017/xx/xx
-  * Bug Fixes
+  * Bug Fixes and Enhancements
   - #3782, Memory leak in lwline_from_wkb_state (Even Rouault)
   - #3101, Fix buffer overflow in pgsql2shp (Sandro Santilli)
   - #3786, ptarray null and heap issues on is_closed
   - #3795, Solaris build issues due to missing isfinite define
            (Julian Schauder)
+  - #3792, mark all 3D related including SFCGAL as parallel safe
 PostGIS 2.3.3
Modified: branches/2.3/doc/xsl/postgis_aggs_mm.xml.xsl
--- branches/2.3/doc/xsl/postgis_aggs_mm.xml.xsl	2017-07-28 04:06:12 UTC (rev 15513)
+++ branches/2.3/doc/xsl/postgis_aggs_mm.xml.xsl	2017-07-28 04:09:54 UTC (rev 15514)
@@ -484,6 +484,7 @@
 			<note><para>PostGIS 2.3.0: PostgreSQL 9.6+ support for parallel queries.</para></note>
 			<note><para>PostGIS 2.3.0: PostgreSQL 9.4+ support for BRIN indexes. Refer to <xref linkend="brin_indexes" />.</para></note>
 			<note><para>PostGIS 2.3.0: Tiger Geocoder upgraded to work with TIGER 2016 data.</para></note>
+			<note><para>PostGIS 2.3.4: All 3D related including SFCGAL marked as parallel safe.</para></note>
 			<sect2 id="NewFunctions_2_3">
 				<title>PostGIS Functions new or enhanced in 2.3</title>
 				<para>The functions given below are PostGIS functions that were added or enhanced.</para>
Modified: branches/2.3/postgis/postgis.sql.in
--- branches/2.3/postgis/postgis.sql.in	2017-07-28 04:06:12 UTC (rev 15513)
+++ branches/2.3/postgis/postgis.sql.in	2017-07-28 04:09:54 UTC (rev 15514)
@@ -5394,49 +5394,49 @@
 CREATE OR REPLACE FUNCTION ST_3DDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'distance3d'
-	LANGUAGE 'c' IMMUTABLE STRICT
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DMaxDistance(geom1 geometry, geom2 geometry)
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'LWGEOM_maxdistance3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DClosestPoint(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_closestpoint3d'
 	COST 1; -- reset cost, see #3675
 CREATE OR REPLACE FUNCTION ST_3DShortestLine(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_shortestline3d'
 CREATE OR REPLACE FUNCTION ST_3DLongestLine(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_longestline3d'
 CREATE OR REPLACE FUNCTION _ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dwithin3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDWithin($1, $2, $3)'
-	LANGUAGE 'sql' IMMUTABLE
+	LANGUAGE 'sql' IMMUTABLE  _PARALLEL
 	COST 100;
 CREATE OR REPLACE FUNCTION _ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dfullywithin3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
@@ -5448,13 +5448,13 @@
 CREATE OR REPLACE FUNCTION _ST_3DIntersects(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','intersects3d'
 	COST 100;
 CREATE OR REPLACE FUNCTION ST_3DIntersects(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_3DIntersects($1, $2)'
 	COST 100;
@@ -5465,7 +5465,7 @@
 CREATE OR REPLACE FUNCTION ST_CoordDim(Geometry geometry)
 	RETURNS smallint
 	AS 'MODULE_PATHNAME', 'LWGEOM_ndims'
 	COST 5;
 -- SQL-MM
@@ -5505,7 +5505,7 @@
 CREATE OR REPLACE FUNCTION _ST_OrderingEquals(GeometryA geometry, GeometryB geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_same'
 	COST 100;
 -- Availability: 1.3.0
@@ -5514,7 +5514,7 @@
 	AS $$
 	SELECT $1 OPERATOR(@extschema at .~=) $2 AND @extschema at ._ST_OrderingEquals($1, $2)
-	LANGUAGE 'sql' IMMUTABLE;
+	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 -- SQL/MM - SQL Functions on type ST_Point
@@ -5814,13 +5814,13 @@
 CREATE OR REPLACE FUNCTION _ST_AsX3D(int4, geometry, int4, int4, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asX3D'
-	LANGUAGE 'c' IMMUTABLE;
+	LANGUAGE 'c' IMMUTABLE _PARALLEL;
 -- ST_AsX3D(geom, precision, options)
 CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
 	RETURNS TEXT
 	AS $$SELECT @extschema at ._ST_AsX3D(3,$1,$2,$3,'');$$
 -- make views and spatial_ref_sys public viewable --
 GRANT SELECT ON TABLE geography_columns TO public;
Modified: branches/2.3/postgis/sfcgal.sql.in
--- branches/2.3/postgis/sfcgal.sql.in	2017-07-28 04:06:12 UTC (rev 15513)
+++ branches/2.3/postgis/sfcgal.sql.in	2017-07-28 04:09:54 UTC (rev 15514)
@@ -32,70 +32,70 @@
 CREATE OR REPLACE FUNCTION ST_3DIntersection(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_intersection3D'
        COST 100;
 -- Availability: 2.2
 CREATE OR REPLACE FUNCTION ST_3DDifference(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_difference3D'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_3DUnion(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_union3D'
        COST 100;
 -- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION ST_Tesselate(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_tesselate'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_3DArea(geometry)
        RETURNS FLOAT8
        AS 'MODULE_PATHNAME','sfcgal_area3D'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_Extrude(geometry, float8, float8, float8)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_extrude'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_ForceLHR(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_force_lhr'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_Orientation(geometry)
        RETURNS INT4
        AS 'MODULE_PATHNAME','sfcgal_orientation'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_MinkowskiSum(geometry, geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_minkowski_sum'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_StraightSkeleton(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_straight_skeleton'
        COST 100;
 -- Availability: 2.2.0
@@ -126,34 +126,35 @@
        AS 'MODULE_PATHNAME','sfcgal_approximate_medial_axis'
        LANGUAGE 'c'
 #endif // POSTGIS_SFCGAL_VERSION >= 12
-       IMMUTABLE STRICT COST 100;
+       IMMUTABLE STRICT _PARALLEL
+       COST 100;
 CREATE OR REPLACE FUNCTION ST_IsPlanar(geometry)
        RETURNS boolean
        AS 'MODULE_PATHNAME','sfcgal_is_planar'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_Volume(geometry)
        RETURNS FLOAT8
        AS 'MODULE_PATHNAME','sfcgal_volume'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_MakeSolid(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_make_solid'
        COST 100;
 CREATE OR REPLACE FUNCTION ST_IsSolid(geometry)
        RETURNS boolean
        AS 'MODULE_PATHNAME','sfcgal_is_solid'
        COST 100;
 COMMIT;
