[postgis-tickets] [PostGIS] #3799: travis is failing
trac at osgeo.org
Mon Jul 31 11:30:21 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
Travis is failing. Might have been happening for some time.
It also might be a bug in our dumprestore test since I don't think any
other bots do that test.
Checking for shp2pgsql ... found
Checking for pgsql2shp ... found
TMPDIR is /tmp/pgis_reg
Database postgis_reg already exists.
Drop it, or run with the --nocreate flag to use it.
make[2]: *** [check] Error 1
make[2]: Leaving directory `/home/travis/build/postgis/postgis/regress'
make[1]: *** [check] Error 1
make[1]: Leaving directory `/home/travis/build/postgis/postgis'
make: *** [installcheck] Error 2
The command "make installcheck RUNTESTFLAGS='--dumprestore'" exited with
2.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3799>
