[postgis-tickets] r15426 - Remove confusing statement
Sandro Santilli strk at kbt.io
Mon Jun 12 06:35:47 PDT 2017
Author: strk
Date: 2017-06-12 06:35:47 -0700 (Mon, 12 Jun 2017)
New Revision: 15426
   trunk/doc/using_postgis_dataman.xml
As reported by Andreas Schild in
https://www.transifex.com/postgis/postgis/translate/#de/using_postgis_datamanxmlpot/19191379/
Modified: trunk/doc/using_postgis_dataman.xml
--- trunk/doc/using_postgis_dataman.xml	2017-06-09 15:23:37 UTC (rev 15425)
+++ trunk/doc/using_postgis_dataman.xml	2017-06-12 13:35:47 UTC (rev 15426)
@@ -90,7 +90,7 @@
 	  SRID information.</para>
 	  <para>Examples of the text representations (EWKT) of the extended
-	  spatial objects of the features are as follows. The * ones are new in this version of PostGIS:</para>
+	  spatial objects of the features are as follows.</para>
 	  <itemizedlist>
 		<listitem>
