[postgis-tickets] [PostGIS] #3771: MultiLineStringZ not working when as first argument for ST_Intersection
trac at osgeo.org
Mon Jun 12 12:23:46 PDT 2017
Reporter: WaltDixie | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: Management
| 2.0
Component: postgis | Version: 2.2.x
Keywords: intersection, multilinestring, 2.5D |
On POSTGIS 2.2, using geos, multilinestringZ aren't handled as expected
when used as first argument in ST_Intersection.
Compare sect1bad to sect1best, sect2bad to sect2best in the following
query:
SELECT li, ST_NumGeometries(geoma),ST_NumGeometries(geomb),
ST_AsText(ST_Intersection(ST_GeometryN(geoma,li),ST_Force3D(ST_Force2D(geomb))))
as sect1best,
ST_AsText(ST_intersection(geoma,ST_Force3D(ST_Force2D(geomb)))) as
sect1bad,
ST_AsText(ST_Intersection(ST_Force3D(ST_Force2D(ST_GeometryN(geoma,li))),geomb))
as sect2best ,
ST_AsText(ST_Intersection(ST_Force3D(ST_Force2D(geoma)),geomb)) as
sect2bad
FROM
( SELECT
ST_GeomFromText('MULTILINESTRING Z ((0 0 10,0 1 11),(0 1 11, 0 10 20))')
as geoma,
ST_GeomFromText('MULTILINESTRING Z ((0 0 5,0 2 9),(0 2 9, 0 3 11))') as
geomb
) data
CROSS JOIN LATERAL generate_series(1,ST_NumGeometries(geoma)) li(li)
GEOS 3D intersection should lead to the average Z-coordinate at each node
of the intersection. This is correctly handled in the 'best' cases, where
the first argument is split into its component LineStringZ segments.
However, in the 'bad' cases, where the first argument is a
MultiLineStringZ, the 'inner' node does not have the average Z-coordinate
but rather retains its original value.
Clearly this functionality can be avoided by splitting the first argument
in its component geometries, but somehow this is not handled by default by
the function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3771>
