[postgis-tickets] r15428 - Style-only change: remove trailing blanks
Sandro Santilli
strk at kbt.io
Tue Jun 13 06:29:21 PDT 2017
Author: strk
Date: 2017-06-13 06:29:21 -0700 (Tue, 13 Jun 2017)
New Revision: 15428
trunk/liblwgeom/lwstroke.c
Modified: trunk/liblwgeom/lwstroke.c
--- trunk/liblwgeom/lwstroke.c 2017-06-12 15:17:00 UTC (rev 15427)
+++ trunk/liblwgeom/lwstroke.c 2017-06-13 13:29:21 UTC (rev 15428)
@@ -18,7 +18,7 @@
- * Copyright 2001-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2006 Refractions Research Inc.
@@ -136,20 +136,20 @@
/* Matched start/end points imply circle */
if ( p1->x == p3->x && p1->y == p3->y )
is_circle = LW_TRUE;
/* Negative radius signals straight line, p1/p2/p3 are colinear */
if ( (radius < 0.0 || p2_side == 0) && ! is_circle )
return NULL;
/* The side of the p1/p3 line that p2 falls on dictates the sweep
direction from p1 to p3. */
if ( p2_side == -1 )
clockwise = LW_TRUE;
else
clockwise = LW_FALSE;
increment = fabs(M_PI_2 / perQuad);
/* Angles of each point that defines the arc section */
a1 = atan2(p1->y - center.y, p1->x - center.x);
a2 = atan2(p2->y - center.y, p2->x - center.x);
@@ -174,7 +174,7 @@
if ( a2 < a1 )
a2 += 2.0 * M_PI;
/* Override angles for circle case */
if( is_circle )
@@ -183,7 +183,7 @@
increment = fabs(increment);
/* Initialize point array */
pa = ptarray_construct_empty(1, 1, 32);
@@ -196,7 +196,7 @@
pt.z = interpolate_arc(angle, a1, a2, a3, p1->z, p2->z, p3->z);
pt.m = interpolate_arc(angle, a1, a2, a3, p1->m, p2->m, p3->m);
ptarray_append_point(pa, &pt, LW_FALSE);
return pa;
@@ -247,7 +247,7 @@
getPoint4d_p(icurve->points, icurve->points->npoints-1, &p1);
ptarray_append_point(ptarray, &p1, LW_TRUE);
oline = lwline_construct(icurve->srid, NULL, ptarray);
return oline;
@@ -530,7 +530,7 @@
b_distance = distance2d_pt_pt(tb, ¢er);
diff = fabs(radius - b_distance);
LWDEBUGF(4, "circle_radius=%g, b_distance=%g, diff=%g, percentage=%g", radius, b_distance, diff, diff/radius);
/* Is the point b on the circle? */
if ( diff < EPSILON_SQLMM )
@@ -565,7 +565,7 @@
for( i = start; i < end + 2; i++ )
getPoint4d_p(pa, i, &p);
- ptarray_set_point4d(pao, j++, &p);
+ ptarray_set_point4d(pao, j++, &p);
return lwline_as_lwgeom(lwline_construct(srid, NULL, pao));
@@ -573,16 +573,16 @@
static LWGEOM*
circstring_from_pa(const POINTARRAY *pa, int srid, int start, int end)
POINT4D p0, p1, p2;
POINTARRAY *pao = ptarray_construct(ptarray_has_z(pa), ptarray_has_m(pa), 3);
LWDEBUGF(4, "srid=%d, start=%d, end=%d", srid, start, end);
getPoint4d_p(pa, start, &p0);
- ptarray_set_point4d(pao, 0, &p0);
+ ptarray_set_point4d(pao, 0, &p0);
getPoint4d_p(pa, (start+end+1)/2, &p1);
- ptarray_set_point4d(pao, 1, &p1);
+ ptarray_set_point4d(pao, 1, &p1);
getPoint4d_p(pa, end+1, &p2);
- ptarray_set_point4d(pao, 2, &p2);
+ ptarray_set_point4d(pao, 2, &p2);
return lwcircstring_as_lwgeom(lwcircstring_construct(srid, NULL, pao));
@@ -619,19 +619,19 @@
/* Null on empty input? */
if ( points->npoints == 0 )
return NULL;
/* We can't desegmentize anything shorter than four points */
if ( points->npoints < 4 )
/* Return a linestring here*/
lwerror("pta_unstroke needs implementation for npoints < 4");
/* Allocate our result array of vertices that are part of arcs */
num_edges = points->npoints - 1;
edges_in_arcs = lwalloc(num_edges + 1);
memset(edges_in_arcs, 0, num_edges + 1);
/* We make a candidate arc of the first two edges, */
/* And then see if the next edge follows it */
while( i < num_edges-2 )
@@ -711,7 +711,7 @@
i = i+1;
#if POSTGIS_DEBUG_LEVEL > 3
char *edgestr = lwalloc(num_edges+1);
@@ -746,7 +746,7 @@
/* Roll out last item */
end = num_edges - 1;
lwcollection_add_lwgeom(outcol, geom_from_pa(points, srid, edge_type, start, end));
/* Strip down to singleton if only one entry */
if ( outcol->ngeoms == 1 )
