[postgis-tickets] r15429 - Style only change: remove trailing blanks
Sandro Santilli
strk at kbt.io
Tue Jun 13 06:29:29 PDT 2017
Author: strk
Date: 2017-06-13 06:29:29 -0700 (Tue, 13 Jun 2017)
New Revision: 15429
trunk/liblwgeom/cunit/cu_ptarray.c
Modified: trunk/liblwgeom/cunit/cu_ptarray.c
--- trunk/liblwgeom/cunit/cu_ptarray.c 2017-06-13 13:29:21 UTC (rev 15428)
+++ trunk/liblwgeom/cunit/cu_ptarray.c 2017-06-13 13:29:29 UTC (rev 15429)
@@ -265,7 +265,7 @@
loc = ptarray_locate_point(line->points, &p, &dist, &l);
CU_ASSERT_EQUAL(loc, 0.5);
CU_ASSERT_EQUAL(dist, 0.0);
- CU_ASSERT_EQUAL(l.m, 10.0);
+ CU_ASSERT_EQUAL(l.m, 10.0);
lwline_free(line);
@@ -337,7 +337,7 @@
//printf("%g\n",area);
CU_ASSERT_DOUBLE_EQUAL(area, -4.0, 0.0000001);
lwline_free(line);
@@ -357,9 +357,9 @@
ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0 1,0 -1)");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("CIRCULARSTRING(-1 0,0 1,0 -1)");
out = lwgeom_stroke(in,8);
lwgeom_free(in);
@@ -370,7 +370,7 @@
ASSERT_STRING_EQUAL(str, "CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1)");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,-1 -1))");
@@ -382,7 +382,7 @@
ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1),(0 -1,-1 -1))");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0 1,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 -2,-1 -3,1 -3),(1 -3,5 5))");
@@ -394,7 +394,7 @@
ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE((-3 -3,-1 0),CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1),(0 -1,0 -1.5,0 -2),CIRCULARSTRING(0 -2,-0.70710678 -3.7071068,1 -3),(1 -3,5 5))");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("COMPOUNDCURVE(CIRCULARSTRING(-1 0,0 1,0 -1),CIRCULARSTRING(0 -1,-1 -2,1 -2))");
@@ -406,8 +406,8 @@
ASSERT_STRING_EQUAL(str, "COMPOUNDCURVE(CIRCULARSTRING(-1 0,0.70710678 0.70710678,0 -1),CIRCULARSTRING(0 -1,-0.70710678 -2.7071068,1 -2))");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("COMPOUNDCURVE((0 0, 1 1), CIRCULARSTRING(1 1, 2 2, 3 1), (3 1, 4 4))");
lwgeom_free(in);
@@ -418,8 +418,8 @@
lwgeom_free(in);
lwgeom_free(out);
// printf("%s\n", str);
- lwfree(str);
+ lwfree(str);
// See http://trac.osgeo.org/postgis/ticket/2425
// and http://trac.osgeo.org/postgis/ticket/2420
in = lwgeom_from_text("LINESTRING(0 0,10 0,10 10,0 10,0 0)");
@@ -428,7 +428,7 @@
ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,10 0,10 10,0 10,0 0)");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
in = lwgeom_from_text("LINESTRING(10 10,0 10,0 0,10 0)");
out = lwgeom_unstroke(in);
@@ -456,7 +456,7 @@
ASSERT_STRING_EQUAL(str, "LINESTRING(0 0,1 1)");
lwgeom_free(in);
lwgeom_free(out);
- lwfree(str);
+ lwfree(str);
@@ -468,7 +468,7 @@
POINTARRAY *pa;
POINT2D pt;
int rv;
lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)"));
pa = lwline->points;
@@ -477,7 +477,7 @@
pt.y = 0.5;
rv = ptarray_contains_point(pa, &pt);
CU_ASSERT_EQUAL(rv, LW_INSIDE);
/* Point on left edge of square */
pt.x = 0;
pt.y = 0.5;
@@ -519,11 +519,11 @@
pt.y = 0.5;
CU_ASSERT_EQUAL(rv, LW_OUTSIDE);
lwline_free(lwline);
lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(0 0, 1 1, 2 0, 0 0)"));
/* Point outside grazing top of triangle */
pt.x = 0;
pt.y = 1;
@@ -567,30 +567,30 @@
pt.y = 0;
rv = ptarrayarc_contains_point(pa, &pt);
/* Point in left lobe */
pt.x = -1.1;
pt.y = 0.1;
- CU_ASSERT_EQUAL(rv, LW_INSIDE);
+ CU_ASSERT_EQUAL(rv, LW_INSIDE);
/* Point on boundary of left lobe */
pt.x = -1;
pt.y = 0;
/* Point on boundary vertex */
pt.x = -1;
pt.y = 1;
- CU_ASSERT_EQUAL(rv, LW_BOUNDARY);
+ CU_ASSERT_EQUAL(rv, LW_BOUNDARY);
/* Point outside */
pt.x = -1.5;
pt.y = 1.5;
- CU_ASSERT_EQUAL(rv, LW_OUTSIDE);
+ CU_ASSERT_EQUAL(rv, LW_OUTSIDE);
/*** Two-edge ring made up of semi-circles (really, a circle) ***/
@@ -601,37 +601,37 @@
pt.x = -1.5;
pt.y = 1.5;
/* Point more outside */
pt.x = 2.5;
pt.y = 1.5;
pt.x = 2.5;
pt.y = 2.5;
/* Point inside at middle */
pt.x = 0;
pt.y = 0;
/* Point inside offset from middle */
pt.x = 0.01;
pt.y = 0.01;
/* Point on edge vertex */
pt.x = 0;
pt.y = 1;
/*** Two-edge ring, closed ***/
@@ -642,7 +642,7 @@
pt.x = 20;
pt.y = 4;
/*** One-edge ring, closed circle ***/
@@ -653,19 +653,19 @@
pt.x = 0;
pt.y = 0;
/* Point outside */
pt.x = 0;
pt.y = 2;
/* Point on boundary */
pt.x = 0;
pt.y = 1;
/*** Overshort ring ***/
