[postgis-tickets] r15433 - It's multi-arc, not multi-arch (typo)
Sandro Santilli strk at kbt.io
Mon Jun 19 09:10:16 PDT 2017
Author: strk
Date: 2017-06-19 09:10:16 -0700 (Mon, 19 Jun 2017)
New Revision: 15433
   trunk/regress/curvetoline.sql
   trunk/regress/curvetoline_expected
Modified: trunk/regress/curvetoline.sql
--- trunk/regress/curvetoline.sql	2017-06-19 16:08:52 UTC (rev 15432)
+++ trunk/regress/curvetoline.sql	2017-06-19 16:10:16 UTC (rev 15433)
@@ -48,13 +48,13 @@
 	2, -- Above is max angle between generating radii
 	3  -- Symmetric and RetainAngle flags
 ), 2));
-SELECT 'multiarch1', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
+SELECT 'multiarc1', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
  'CIRCULARSTRING(0 0,100 -100,200 0,400 200,600 0)'::geometry,
 	radians(45), -- Tolerance
 ), 2));
-SELECT 'multiarch1.maxerr20.sym', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
+SELECT 'multiarc1.maxerr20.sym', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
 	20, -- Tolerance
 	1, -- Above is max distance between curve and line
Modified: trunk/regress/curvetoline_expected
--- trunk/regress/curvetoline_expected	2017-06-19 16:08:52 UTC (rev 15432)
+++ trunk/regress/curvetoline_expected	2017-06-19 16:10:16 UTC (rev 15433)
@@ -4,5 +4,5 @@
 semicircle3|LINESTRING(0 0,24 -64,82 -98,150 -86,194 -34,200 0)
 semicircle3.sym|LINESTRING(0 0,20 -58,70 -96,130 -96,180 -58,200 0)
 semicircle3.sym.ret|LINESTRING(0 0,14 -50,66 -94,134 -94,186 -50,200 0)
-multiarch1|LINESTRING(0 0,30 -70,100 -100,170 -70,200 0,258 142,400 200,542 142,600 0)
-multiarch1.maxerr20.sym|LINESTRING(0 0,50 -86,150 -86,200 0,258 142,400 200,542 142,600 0)
+multiarc1|LINESTRING(0 0,30 -70,100 -100,170 -70,200 0,258 142,400 200,542 142,600 0)
+multiarc1.maxerr20.sym|LINESTRING(0 0,50 -86,150 -86,200 0,258 142,400 200,542 142,600 0)
