[postgis-tickets] [PostGIS] #3775: Extension upgrade scripts keep growing on every new `make` invocation
trac at osgeo.org
Mon Jun 19 13:23:14 PDT 2017
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: build/upgrade/install | Version: trunk
Keywords: |
At some point I had 35 CREATE OR REPLACE lines for ST_Curve.
It's just that I don't usually `make clean` before running `make` again,
after changes. This results in extension scripts growing and growing, as
the postgis_upgrade.sql script simply gets appended to them...
Crazy stuff.
This was in trunk (2.4.0dev) - hadn't tested in other branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3775>
