[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Mon Jun 19 18:11:07 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay this is proving to be trickier than I thought.
I tried changing:
FOR rec2 IN SELECT CASE rec.dims
WHEN 0 THEN
topology.topogeo_addPoint(atopology, rec.geom, tolerance)
WHEN 1 THEN
topology.topogeo_addLineString(atopology, rec.geom, tolerance)
WHEN 2 THEN
topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
END as primitive
LOOP
To:
WHEN 0 THEN
(SELECT poi FROM topology.topogeo_addPoint(atopology, rec.geom,
tolerance) AS poi LIMIT 1 )
WHEN 1 THEN
(SELECT li FROM topology.topogeo_addLineString(atopology,
rec.geom, tolerance) AS li LIMIT 1)
WHEN 2 THEN
(SELECT poly FROM topology.topogeo_addPolygon(atopology,
rec.geom, tolerance) AS poly LIMIT 1)
END as primitive
LOOP
and while that fixed st_simplify and topogeom_edit regress,
it broke both my 9.6 and 10 in a consistent way on the totopogeom test.
I'm not sure what is the difference between the two constructs above. I
would expect them to be equivalent.
regress/legacy_validate .. ok
regress/legacy_predicate .. ok
regress/legacy_invalid .. ok
regress/sqlmm .. ok
regress/legacy_query .. ok
regress/addnode .. ok
regress/addedge .. ok
regress/addface .. ok
regress/addface2.5d .. ok
regress/addtopogeometrycolumn .. ok
regress/polygonize .. ok
regress/st_addisoedge .. ok
regress/st_addisonode .. ok
regress/st_addedgemodface .. ok
regress/st_addedgenewfaces .. ok
regress/st_changeedgegeom .. ok
regress/st_createtopogeo .. ok
regress/st_getfacegeometry .. ok
regress/st_getfaceedges .. ok
regress/st_modedgeheal .. ok
regress/st_modedgesplit .. ok
regress/st_newedgeheal .. ok
regress/st_newedgessplit .. ok
regress/st_remedgenewface .. ok
regress/st_remedgemodface .. ok
regress/st_simplify .. ok
regress/topoelement .. ok
regress/topoelementarray_agg .. ok
regress/topogeo_addlinestring .. ok
regress/topogeo_addpoint .. ok
regress/topogeo_addpolygon .. ok
regress/topogeom_edit .. ok
regress/topogeometry_type .. ok
regress/topojson .. ok
regress/topologysummary .. ok
regress/topo2.5d .. ok
regress/totopogeom .. failed (diff expected obtained:
/projects/postgis/tmp/2.4_pg9.6w64/test_37_diff)
regress/droptopology .. ok
regress/droptopogeometrycolumn .. ok
regress/copytopology .. ok
regress/createtopogeom .. ok
regress/createtopology .. ok
regress/gml .. ok
regress/getnodebypoint .. ok
regress/getedgebypoint .. ok
regress/getfacebypoint .. ok
regress/getringedges .. ok
regress/gettopogeomelements .. ok
regress/layertrigger .. ok
regress/validatetopology .. ok
uninstall .. ok (4581)
--- regress/totopogeom_expected 2016-04-27 10:57:37.107702900 -0400
+++ /projects/postgis/tmp/2.4_pg9.6w64/test_37_out 2017-06-19
21:07:59.909850400 -0400
@@ -32,9 +32,9 @@
MULTIPOLYGON EMPTY
MULTIPOLYGON EMPTY
GEOMETRYCOLLECTION EMPTY
-tolerance_1|0.5
-tolerance_topo_1|0.5
-tolerance_0|0
+tolerance_1|8.04984471899924
+tolerance_topo_1|8.04984471899924
+tolerance_0|8.04984471899924
custom_search_path|0
#1790.1|0|0
#1790.2|0|0
@@ -46,7 +46,7 @@
tgup1.3|5|200|4
#3359.setval|1|2|1
#3359.line.1|1
-#3359.line.2|2
+#3359.line.2|1
#3359.area.1|1
-#3359.area.2|2
+#3359.area.2|1
Topology 'tt' dropped
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:9>
