[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Mon Jun 19 12:41:42 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Alright guess it's time to refix this. As expected the new change to
PostgreSQL 10 broke my fragile fix.
PostgreSQL 10beta1 on x86_64-pc-linux-gnu, compiled by gcc (Debian
5.2.1-22) 5.2.1 20151010, 64-bit
Postgis 2.4.0dev - r15433 - 2017-06-19 18:39:00
scripts 2.4.0dev r15433
GEOS: 3.7.0dev-CAPI-1.11.0 8fe2ce62
PROJ: Rel. 4.9.2, 08 September 2015
Running tests
regress/legacy_validate .. ok
regress/legacy_predicate .. ok
regress/legacy_invalid .. ok
regress/sqlmm .. ok
regress/legacy_query .. ok
regress/addnode .. ok
regress/addedge .. ok
regress/addface .. ok
regress/addface2.5d .. ok
regress/addtopogeometrycolumn .. ok
regress/polygonize .. ok
regress/st_addisoedge .. ok
regress/st_addisonode .. ok
regress/st_addedgemodface .. ok
regress/st_addedgenewfaces .. ok
regress/st_changeedgegeom .. ok
regress/st_createtopogeo .. ok
regress/st_getfacegeometry .. ok
regress/st_getfaceedges .. ok
regress/st_modedgeheal .. ok
regress/st_modedgesplit .. ok
regress/st_newedgeheal .. ok
regress/st_newedgessplit .. ok
regress/st_remedgenewface .. ok
regress/st_remedgemodface .. ok
regress/st_simplify .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_26_diff)
--- regress/st_simplify_expected 2017-02-07 07:21:40.613359496
+0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_26_out
2017-06-19 18:45:00.070826465 +0000
@@ -1,9 +1,8 @@
t
L1
-N2
-S1|f|t
-S2|f|t
+ERROR: set-returning functions are not allowed in CASE at character 227
+N1
+S1|f|
+S2|f|
L2
-HS1|f|t
-HS2|f|t
f
regress/topoelement .. ok
regress/topoelementarray_agg .. ok
regress/topogeo_addlinestring .. ok
regress/topogeo_addpoint .. ok
regress/topogeo_addpolygon .. ok
regress/topogeom_edit .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_32_diff)
--- regress/topogeom_edit_expected 2017-02-07 07:21:40.665359497
+0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_32_out
2017-06-19 18:45:04.182826481 +0000
@@ -1,8 +1,5 @@
create|t
simple_line_layer|1
-1|start|1|10
-1|add|1|30
-1|rem|1|20
-1|dup|1|20
-1|mis|1|20
Topology 'tt' dropped
regress/topogeometry_type .. ok
regress/topojson .. ok
regress/topologysummary .. ok
regress/topo2.5d .. ok
regress/totopogeom .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_37_diff)
--- regress/totopogeom_expected 2017-02-07 07:21:40.633359496 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg10.0w64/test_37_out
2017-06-19 18:45:07.298826492 +0000
@@ -18,13 +18,13 @@
ERROR: Unsupported feature type TIN
ERROR: Unsupported feature type TRIANGLE
ERROR: Unsupported feature type CIRCULARSTRING
-POINT(0 0)|t
-LINESTRING(0 10,10 10)|t
-POLYGON((0 20,10 20,5 30,0 20),(2 22,8 22,5 28,2 22))|t
-MULTIPOINT(0 -10,5 -10)|t
-MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
-MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102
22)),((80 20,90 20,90 60,80 20)))|t
-GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
-90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
-72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
-91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
-78)),((-20 -80,-10 -80,-10 -40,-20
-80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
-80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2
-78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20
-80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
-90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
MULTIPOINT EMPTY
MULTIPOINT EMPTY
MULTILINESTRING EMPTY
@@ -32,21 +32,19 @@
MULTIPOLYGON EMPTY
MULTIPOLYGON EMPTY
GEOMETRYCOLLECTION EMPTY
-tolerance_1|0.5
-tolerance_topo_1|0.5
-tolerance_0|0
-custom_search_path|0
-#1790.1|0|0
-#1790.2|0|0
-#1790.3|0|0
-#1968.1|0
-#1968.2|0
-tgup1.1|5|100|1
-tgup1.2|5|200|2
-tgup1.3|5|200|4
#3359.setval|1|2|1
-#3359.line.1|1
-#3359.line.2|2
-#3359.area.1|1
-#3359.area.2|2
regress/droptopology .. ok
regress/droptopogeometrycolumn .. ok
regress/copytopology .. ok
regress/createtopogeom .. ok
regress/createtopology .. ok
regress/gml .. ok
regress/getnodebypoint .. ok
regress/getedgebypoint .. ok
regress/getfacebypoint .. ok
regress/getringedges .. ok
regress/gettopogeomelements .. ok
regress/layertrigger .. ok
regress/validatetopology .. ok
uninstall . /var/lib/jenkins/workspace/postgis/branches/2.4/regress/00
-regress-install/share/contrib/postgis/uninstall_topology.sql
/var/lib/jenkins/workspace/postgis/branches/2.4/regress/00-regress-
install/share/contrib/postgis/uninstall_postgis.sql
. ok (4662)
Run tests: 51
Failed: 3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:8>
