[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Tue Jun 20 15:16:19 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: reopened => closed
* resolution: => fixed
Comment:
In [changeset:"15438" 15438]:
#!CommitTicketReference repository="" revision="15438"
refix for PostgreSQL 10 changed CASE WHEN set returning behavior
Don't use CASE using UNION ALL instead with a WHERE that when resolves to
false skips the output call.
Closes #3764 for PostGIS 2.4 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:13>
