[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Tue Jun 20 16:29:37 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Comment (by robe):
In [changeset:"15439" 15439]:
#!CommitTicketReference repository="" revision="15439"
Clean up of formatting of r15406.
Add some explanation of change from CASE to UNION ALL
change SELECT ST_Dump to FROM ST_Dump per strk's suggestion
References #3764
For more details refer to https://www.postgresql.org/message-
id/000001d2d5de%24d8d66170%248a832450%24%40pcorp.us
and commit that I think introduced the original problem -
https://www.postgresql.org/message-id/E1cTy4K-00085H-
5v at gemulon.postgresql.org
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:14>
