[postgis-tickets] r15439 - Clean up of formatting of r15406.
Regina Obe
lr at pcorp.us
Tue Jun 20 16:29:37 PDT 2017
Author: robe
Date: 2017-06-20 16:29:37 -0700 (Tue, 20 Jun 2017)
New Revision: 15439
trunk/topology/sql/topogeometry/totopogeom.sql.in
Add some explanation of change from CASE to UNION ALL
change SELECT ST_Dump to FROM ST_Dump per strk's suggestion
References #3764
For more details refer to https://www.postgresql.org/message-id/000001d2d5de%24d8d66170%248a832450%24%40pcorp.us
and commit that I think introduced the original problem - https://www.postgresql.org/message-id/E1cTy4K-00085H-5v@gemulon.postgresql.org
Modified: trunk/topology/sql/topogeometry/totopogeom.sql.in
--- trunk/topology/sql/topogeometry/totopogeom.sql.in 2017-06-20 22:16:18 UTC (rev 15438)
+++ trunk/topology/sql/topogeometry/totopogeom.sql.in 2017-06-20 23:29:37 UTC (rev 15439)
@@ -236,16 +236,24 @@
-- definition by splitting
FOR rec IN SELECT id(tg), alayer as lyr,
geom, ST_Dimension(geom) as dims
- FROM (SELECT (ST_Dump(ageom)).geom) as f
+ FROM (SELECT gd.geom FROM ST_Dump(ageom) AS gd ) as f
WHERE NOT ST_IsEmpty(geom)
LOOP
+ -- NOTE: Switched from using case to this because of PG 10 behavior change
+ -- Using a UNION ALL only one will be processed because of the WHERE
+ -- Since the WHERE clause will be processed first
FOR rec2 IN SELECT primitive
- FROM
- (SELECT topology.topogeo_addPoint(atopology, rec.geom, tolerance) WHERE rec.dims = 0
- UNION ALL
- SELECT topology.topogeo_addLineString(atopology, rec.geom, tolerance) WHERE rec.dims = 1
- UNION ALL
- SELECT topology.topogeo_addPolygon(atopology, rec.geom, tolerance) WHERE rec.dims = 2 ) AS f(primitive)
+ FROM
+ SELECT topology.topogeo_addPoint(atopology, rec.geom, tolerance)
+ WHERE rec.dims = 0
+ UNION ALL
+ SELECT topology.topogeo_addLineString(atopology, rec.geom, tolerance)
+ WHERE rec.dims = 1
+ UNION ALL
+ SELECT topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
+ WHERE rec.dims = 2
+ ) AS f(primitive)
LOOP
elem := ARRAY[rec.dims+1, rec2.primitive]::text;
IF elems @> ARRAY[elem] THEN
