[postgis-tickets] r15440 - simplification per strk's request. I undersimplified on last commit.
Regina Obe lr at pcorp.us
Wed Jun 21 04:23:11 PDT 2017
Author: robe
Date: 2017-06-21 04:23:11 -0700 (Wed, 21 Jun 2017)
New Revision: 15440
   trunk/topology/sql/topogeometry/totopogeom.sql.in
Modified: trunk/topology/sql/topogeometry/totopogeom.sql.in
--- trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-20 23:29:37 UTC (rev 15439)
+++ trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-21 11:23:11 UTC (rev 15440)
@@ -235,9 +235,9 @@
   -- as possible so that each element can further edit the
   -- definition by splitting
   FOR rec IN SELECT id(tg), alayer as lyr,
-    geom, ST_Dimension(geom) as dims
-    FROM (SELECT gd.geom FROM ST_Dump(ageom) AS gd ) as f
-    WHERE NOT ST_IsEmpty(geom)
+    geom, ST_Dimension(gd.geom) as dims
+    FROM ST_Dump(ageom) AS gd
+    WHERE NOT ST_IsEmpty(gd.geom)
   LOOP
     -- NOTE: Switched from using case to this because of PG 10 behavior change
     -- Using a UNION ALL only one will be processed because of the WHERE
