[postgis-tickets] [PostGIS] #3777: POINT EMPTY, POINT 0 0 anomaly
trac at osgeo.org
Wed Jun 21 05:42:55 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Keywords: |
As Pierre pointed out in:
https://lists.osgeo.org/pipermail/postgis-users/2017-June/042203.html
We've got what appears to be a bug with our handling of POINT EMPTY, POINT
0 0.
Tested on PostGIS 2.3 and 2.4
SELECT ST_AsText(geom) txt, count(*)
FROM (
SELECT 'POINT(0 0)'::geometry geom
UNION ALL
UNION ALL
UNION ALL
SELECT 'POINT(0 1)'::geometry geom
UNION ALL
SELECT 'LINESTRING(0 0,0 1)'::geometry geom
UNION ALL
SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
UNION ALL
SELECT 'POINT EMPTY'::geometry geom
) foo
GROUP BY geom;
Yields:
txt | count
POINT(0 0) | 2
POINT EMPTY | 1
POINT(0 0) | 1
LINESTRING(0 0,0 1) | 1
GEOMETRYCOLLECTION EMPTY | 1
POINT(0 1) | 1
when it should be yielding something along the lines of:
txt | count
POINT(0 0) | 3
GEOMETRYCOLLECTION EMPTY | 2
POINT(0 1) | 1
Since POINT EMPTY and GEOMETRYCOLLECTION have null boxes they should
aggregate together and since points and 2 point lines should have no
boxes, they should be taken literally.
I did the same exercise in PostGIS 1.5 and got this:
txt | count
GEOMETRYCOLLECTION EMPTY | 4
POINT(0 1) | 1
(4 rows)
which I attributed to the fact that at one point of time, since we had no
concept of POINT EMPTY we always output the representation as
GEOMETRYCOLLECTION EMPTY and I think there was one function that used
POINT(0 0) as rep for POINT EMPTY. Though I could be mistaken.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3777>
