[postgis-tickets] [PostGIS] #3773: ‘last_old_id’ may be used uninitialized in function ‘UF_get_collapsed_cluster_ids’
    trac at osgeo.org
    Fri Jun 23 08:02:40 PDT 2017
  Reporter:  strk     |      Owner:  dbaston
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.3.3
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by dbaston):
 Not sure if I'll get to it or not.  There's no error here, but it should
 be possible to restructure it to make the warning go away.  Which compiler
 is producing the error?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3773#comment:2>
