[postgis-tickets] [PostGIS] #3773: ‘last_old_id’ may be used uninitialized in function ‘UF_get_collapsed_cluster_ids’
trac at osgeo.org
Fri Jun 23 07:55:31 PDT 2017
Reporter: strk | Owner: dbaston
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.3.3
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by strk):
* milestone: PostGIS 2.4.0 => PostGIS 2.3.3
Comment:
2.3 branch is also affected.
Daniel will you look at this before next week ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3773#comment:1>
