[postgis-tickets] r15449 - Fix compiler warnings about printf-like formats
Sandro Santilli
strk at kbt.io
Fri Jun 23 08:07:50 PDT 2017
Author: strk
Date: 2017-06-23 08:07:50 -0700 (Fri, 23 Jun 2017)
New Revision: 15449
branches/2.3/topology/postgis_topology.c
This was already fixed in trunk
Modified: branches/2.3/topology/postgis_topology.c
--- branches/2.3/topology/postgis_topology.c 2017-06-23 14:58:58 UTC (rev 15448)
+++ branches/2.3/topology/postgis_topology.c 2017-06-23 15:07:50 UTC (rev 15449)
@@ -1423,9 +1423,9 @@
if ( SPI_processed ) topo->be_data->data_changed = true;
if ( SPI_processed != numelems ) {
- cberror(topo->be_data, "processed %u rows, expected %d",
- SPI_processed, numelems);
- return 0;
+ cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected %d",
+ (uint64)SPI_processed, numelems);
+ return 0;
/* Set node_id (could skip this if none had it set to -1) */
@@ -1480,9 +1480,9 @@
POSTGIS_DEBUGF(1, "cb_insertEdges query processed %d rows", SPI_processed);
- return -1;
+ return -1;
if ( needsEdgeIdReturn )
@@ -1538,9 +1538,9 @@
POSTGIS_DEBUGF(1, "cb_insertFaces query processed %d rows", SPI_processed);
- return -1;
+ return -1;
if ( needsFaceIdReturn )
@@ -1904,8 +1904,9 @@
if ( SPI_processed != 1 ) {
- cberror(topo->be_data, "processed %d rows, expected 1", SPI_processed);
- return -1;
+ cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected 1",
+ (uint64)SPI_processed);
+ return -1;
dat = SPI_getbinval( SPI_tuptable->vals[0],
