[postgis-tickets] r15450 - Fix lwgeom_cmp return code
Sandro Santilli
strk at kbt.io
Fri Jun 23 15:16:59 PDT 2017
Author: strk
Date: 2017-06-23 15:16:59 -0700 (Fri, 23 Jun 2017)
New Revision: 15450
trunk/postgis/lwgeom_btree.c
trunk/regress/operators.sql
trunk/regress/operators_expected
See #3777
Modified: trunk/postgis/lwgeom_btree.c
--- trunk/postgis/lwgeom_btree.c 2017-06-23 15:07:50 UTC (rev 15449)
+++ trunk/postgis/lwgeom_btree.c 2017-06-23 22:16:59 UTC (rev 15450)
@@ -345,9 +345,20 @@
PG_FREE_IF_COPY(geom1, 0);
PG_FREE_IF_COPY(geom2, 1);
- if ( empty1 != empty2 )
+ if ( empty1 || empty2 )
- PG_RETURN_BOOL(FALSE);
+ if ( empty1 && empty2 )
+ PG_RETURN_INT32(1);
+ else if ( empty1 )
+ PG_RETURN_INT32(-1);
+ else
if ( ! FPeq(box1.xmin , box2.xmin) )
Modified: trunk/regress/operators.sql
--- trunk/regress/operators.sql 2017-06-23 15:07:50 UTC (rev 15449)
+++ trunk/regress/operators.sql 2017-06-23 22:16:59 UTC (rev 15450)
@@ -151,4 +151,13 @@
SELECT 'POINT EMPTY'::geometry
) foo
GROUP BY geom ORDER BY 2;
+SELECT '#3777.1', ST_AsText(geom), count(*) FROM (
+SELECT 'POINT(0 0)'::geometry geom UNION ALL
+SELECT 'POINT(0 0)'::geometry UNION ALL
+SELECT 'POINT EMPTY'::geometry UNION ALL
+SELECT 'POINT(0 1)'::geometry UNION ALL
+SELECT 'LINESTRING(0 0,0 1)'::geometry UNION ALL
+SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
+) foo
+GROUP BY geom ORDER BY 2;
Modified: trunk/regress/operators_expected
--- trunk/regress/operators_expected 2017-06-23 15:07:50 UTC (rev 15449)
+++ trunk/regress/operators_expected 2017-06-23 22:16:59 UTC (rev 15450)
@@ -60,3 +60,7 @@
#3777|LINESTRING(0 0,0 1)|1
#3777|POINT(0 0)|3
#3777|POINT(0 1)|1
+#3777.1|GEOMETRYCOLLECTION EMPTY|2
+#3777.1|LINESTRING(0 0,0 1)|1
+#3777.1|POINT(0 0)|3
+#3777.1|POINT(0 1)|1
