[postgis-tickets] [PostGIS] #3704: ST_AsX3D returns random data / crashes client
trac at osgeo.org
Fri Jun 23 21:02:27 PDT 2017
Reporter: Mike Toews | Owner: robe
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by robe):
okay figured out why garden test didn't pick this up.
It was testing this:
SELECT ST_AsX3D(foo1.the_geom, 3, 5) As result
FROM ((SELECT
ST_GeomFromText('POINT EMPTY',4326) As the_geom
UNION ALL SELECT ST_GeomFromText('MULTIPOINT
UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
UNION ALL SELECT ST_GeomFromText('LINESTRING
UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
EMPTY',4326) As the_geom ) ) As foo1 LIMIT 3;
Which because of the limit never got to testing LINESTRING EMPTY. Guess I
got to increase the limit on this so covers the number of empties.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3704#comment:5>
