[postgis-tickets] [PostGIS] #3751: Parallel support for aggregates with transitions
trac at osgeo.org
Tue Jun 6 14:29:56 PDT 2017
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Changes (by robe):
* cc: pramsey (added)
Comment:
I was hoping this was an already tested bit, but it seems I was mistaken,
array_agg and string_agg do not use the new serialfunc, deserialfunc.
Most cases I found in postgresql source code are a bit trivial-er. I
asked on mailing list why this is so, and seems they might not have gotten
to it.
Last comment from Andres Freund:
https://www.postgresql.org/message-
id/20170606192609.lgwzs2pcr4ng7et5%40alap3.anarazel.de
> > It seems CREATE AGGREGATE was expanded in 9.6 to support
parallelization of
> > aggregate functions using transitions, with the addition of serialfunc
and
> > deserialfunc to the aggregate definitions.
> > https://www.postgresql.org/docs/10/static/sql-createaggregate.html
> > I was looking at the PostgreSQL 10 source code for some example usages
of
> > this and was hoping that array_agg and string_agg would support the
feature.
> > At a cursory glance, it seems they do not use this.
> > Examples I see that do support it are the average and standard
deviation
> > functions.
> > Is there a reason for this or it just wasn't gotten to?
I'd suggest trying to write a parallel version of them ;). Shouldn't be
too hard.
@pramsey have you had a chance to look at this yet?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3751#comment:2>
