[postgis-tickets] [PostGIS] #3717: geocode_intersection documentation has wrong parameter name for maximum results returned
trac at osgeo.org
Fri Jun 23 22:33:00 PDT 2017
results returned
Reporter: znmeb | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.3
Component: documentation | Version: 2.3.x
Resolution: fixed | Keywords: geocoder, intersection
Comment (by robe):
I actually like the term max_results better since it may return fewer than
that.
That said the docs should agree. I might change the name in PostGIS 2.4
though to num_results (and mark as possible breaking change).
I have other changes in works on PostGIS 2.4 that are half done, so not
going to commit to 2.4 yet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3717#comment:2>
