[postgis-tickets] r15459 - Specify highest version of PostgreSQL supported.
Regina Obe lr at pcorp.us
Fri Jun 23 22:36:23 PDT 2017
Author: robe
Date: 2017-06-23 22:36:22 -0700 (Fri, 23 Jun 2017)
New Revision: 15459
   branches/2.3/doc/installation.xml
References #3762 for PostGIS 2.3.3
Modified: branches/2.3/doc/installation.xml
--- branches/2.3/doc/installation.xml	2017-06-24 05:31:35 UTC (rev 15458)
+++ branches/2.3/doc/installation.xml	2017-06-24 05:36:22 UTC (rev 15459)
@@ -94,7 +94,7 @@
 	<itemizedlist>
 	  <listitem>
 		<para>
-		  PostgreSQL &min_postgres_version; or higher. A complete installation
+		  PostgreSQL &min_postgres_version; and >= PostgreSQL 9.6. A complete installation
 		  of PostgreSQL (including server headers) is required. PostgreSQL
 		  is available from
 		  <ulink url="http://www.postgresql.org">
@@ -1395,7 +1395,7 @@
 	<para>You can later run <filename>uninstall_legacy.sql</filename> to get rid of the deprecated functions after you are done with restoring and cleanup.</para>
   </sect1>
     <sect1 id="create_new_db">
 	<title>Create a spatially-enabled database without using extensions</title>
