[postgis-tickets] r15470 - update ChangeLog in prep for PostGIS 2.3.3 release
Regina Obe
lr at pcorp.us
Fri Jun 30 20:22:13 PDT 2017
Author: robe
Date: 2017-06-30 20:22:13 -0700 (Fri, 30 Jun 2017)
New Revision: 15470
branches/2.3/ChangeLog
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog 2017-06-30 20:43:48 UTC (rev 15469)
+++ branches/2.3/ChangeLog 2017-07-01 03:22:13 UTC (rev 15470)
@@ -1,3 +1,218 @@
+2017-06-30 20:43 Regina Obe <lr at pcorp.us>
+ * [r15469] doc/performance_tips.xml, doc/using_postgis_dataman.xml:
+ Bring performance tips section up to newer versions
+ Closes #3746 for PostGIS 2.3 (branch)
+2017-06-24 06:18 Regina Obe <lr at pcorp.us>
+ * [r15463] .travis.yml: try to fix travis gdal related build error
+2017-06-24 05:36 Regina Obe <lr at pcorp.us>
+ * [r15460] doc/installation.xml: fix typo
+ * [r15459] doc/installation.xml: Specify highest version of
+ PostgreSQL supported.
+ References #3762 for PostGIS 2.3.3
+2017-06-24 05:31 Regina Obe <lr at pcorp.us>
+ * [r15458] doc/extras_tigergeocoder.xml: change doco for
+ Geocode_Intersection to agree with function definition.
+ Closes #3717 for PostGIS 2.3.3
+2017-06-24 04:58 Regina Obe <lr at pcorp.us>
+ * [r15457] NEWS, raster/rt_pg/rtpg_mapalgebra.c: Change ST_Clip
+ from Error to Notice when ST_Clip can compute no band
+ Closest #3730 for PostGIS 2.3.3
+2017-06-24 04:33 Regina Obe <lr at pcorp.us>
+ * [r15454] doc/reference_processing.xml: Update 3D example and put
+ a note about function may return the same geometry.
+ References #3702 for PostGIS 2.4 (trunk)
+2017-06-24 04:06 Regina Obe <lr at pcorp.us>
+ * [r15452] doc/xsl/postgis_gardentest.sql.xsl: Increase LIMIT
+ clause on tests so can more readily catch issues like #3704.
+2017-06-23 22:57 Sandro Santilli <strk at kbt.io>
+ * [r15451] postgis/lwgeom_btree.c, regress/operators.sql,
+ regress/operators_expected: Fix lwgeom_cmp return code
+ Closes #3777 once again (for 2.3 branch)
+2017-06-23 15:07 Sandro Santilli <strk at kbt.io>
+ * [r15449] topology/postgis_topology.c: Fix compiler warnings about
+ printf-like formats
+ This was already fixed in trunk
+2017-06-23 14:58 Sandro Santilli <strk at kbt.io>
+ * [r15448] NEWS, postgis/lwgeom_btree.c, regress/operators.sql,
+ regress/operators_expected: Fix handling of EMPTY geometries in
+ btree operator
+ Includes regress test
+ Closes #3777 for 2.3 branch
+2017-06-23 06:15 Regina Obe <lr at pcorp.us>
+ * [r15445] NEWS, liblwgeom/lwout_x3d.c, regress/tickets.sql,
+ regress/tickets_expected: ST_AsX3D handle empty geometries
+ Closes #3704 for PostGIS 2.3.3
+2017-06-23 05:55 Regina Obe <lr at pcorp.us>
+ * [r15443] regress/dumper/realtable-pre.sql: Backport test sql
+ script missed in last commit
+ References #3682 for 2.3.3
+ References #3701 for 2.3.3
+2017-06-23 05:19 Regina Obe <lr at pcorp.us>
+ * [r15442] NEWS, loader/pgsql2shp-core.c, loader/pgsql2shp-core.h,
+ regress/dumper/realtable_expected.dbf: Backport fixes for
+ pgsql2shp for Boolean field length and quote escaping
+ Includes tests for both
+ Closes #3682
+ Closes #3701
+2017-06-19 20:37 Sandro Santilli <strk at kbt.io>
+ * [r15437] postgis/Makefile.in: Avoid ever-growing postgis
+ extension upgrade scripts
+ Fixes #3775 for 2.3 branch
+ * [r15436] postgis/Makefile.in: Style only change: remove trailing
+ blanks
+2017-06-06 12:27 Sandro Santilli <strk at kbt.io>
+ * [r15421] NEWS, doc/po/de_DE/release_notes.xml.po,
+ doc/po/es/release_notes.xml.po, doc/po/fr/release_notes.xml.po,
+ doc/po/it_IT/release_notes.xml.po,
+ doc/po/ja/release_notes.xml.po,
+ doc/po/ko_KR/release_notes.xml.po,
+ doc/po/pl/release_notes.xml.po,
+ doc/po/pt_BR/release_notes.xml.po,
+ doc/po/templates/release_notes.xml.pot, doc/release_notes.xml:
+ Speep up -> Speed up
+ Thanks Andreas Schild via
+ https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993598/
+2017-06-06 12:22 Sandro Santilli <strk at kbt.io>
+ * [r15418] NEWS, doc/release_notes.xml: shp2pgsql locale fixes are
+ #3084, not #3048
+ https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993584/
+2017-05-04 18:01 Sandro Santilli <strk at kbt.io>
+ * [r15388] .drone.yml: Set RUNTESTFLAGS env variable locally
+ global env doesn't seem to work with Drone
+2017-05-03 03:50 Regina Obe <lr at pcorp.us>
+ * [r15383] NEWS, postgis/postgis.sql.in,
+ raster/rt_pg/rtpostgis.sql.in: @ operator not schema qualified
+ and ~ not schema qualified in some places
+ apply patch with adjustments. Patch provided by Shane StClair
+ (Axiom Data Science)
+ Closes #3750 for PostGIS 2.3.3
+2017-04-25 08:20 Regina Obe <lr at pcorp.us>
+ * [r15368] regress/subdivide.sql, regress/subdivide_expected:
+ revise ST_Subdivide regress to use ticket instead of github pull
+ request
+ References #3744 for PostGIS 2.3
+2017-04-25 06:02 Regina Obe <lr at pcorp.us>
+ * [r15365] NEWS, doc/Makefile.in, doc/texstyle.sty: PDF manual from
+ dblatex renders fancy quotes for programlisting
+ Change to use regular quotes
+ patch from Mike Toews
+ References #3726 for PostGIS 2.3
+2017-04-24 20:42 Regina Obe <lr at pcorp.us>
+ * [r15364] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
+ regress/subdivide_expected: ST_Subdivide loses subparts of
+ inverted geometries patch from Darafei Praliaskouski (Komzpa)
+ Closes #3744 for PostGIS 2.3
+ changed area regress to cast to numeric so doesn't return
+ scientific notation on windows
+2017-04-23 20:34 Regina Obe <lr at pcorp.us>
+ * [r15362] NEWS, raster/loader/raster2pgsql.c: Get rid of logic
+ that set out_srid to same as input srid and change to not try to
+ transform when out_srid is unknown.
+ Closes #3738 for PostGIS 2.3
+2017-04-12 13:35 Sandro Santilli <strk at kbt.io>
+ * [r15352] README.md: Fix drone build badge url
+ [ci skip]
+2017-04-08 12:25 Regina Obe <lr at pcorp.us>
+ * [r15348] regress/knn_recheck.sql, regress/knn_recheck_expected:
+ Get rid of knn tests where multiple records have the same
+ distances
+ references #3649 for 2.3
+2017-04-04 17:40 Daniel Baston <dbaston at gmail.com>
+ * [r15346] doc/reference_measure.xml: Fix error in docs for
+ ST_ClusterDBSCAN
+2017-03-11 16:23 Sandro Santilli <strk at kbt.io>
+ * [r15331] NEWS, liblwgeom/lwgeom_topo.c,
+ topology/test/regress/topogeo_addlinestring.sql,
+ topology/test/regress/topogeo_addlinestring_expected_newsnap,
+ topology/test/regress/topogeo_addlinestring_expected_oldsnap: Fix
+ azimuth computation for 2.5D edge ends
+ The change disreguard vertical movemements of the edge and
+ computes
+ azimuth of the first segment getting away from the node.
+ Includes automated testcase
+ Closes #3711 (in 2.3 branch)
+2017-01-31 05:05 Regina Obe <lr at pcorp.us>
+ * [r15303] Version.config, extensions/upgradeable_versions.mk: Bump
+ to next dev revision
+2017-01-30 05:59 Regina Obe <lr at pcorp.us>
+ * [r15301] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk: Prep
+ for PostGIS 2.3.2 release
2017-01-28 04:10 Regina Obe <lr at pcorp.us>
* [r15295] liblwgeom/lwprint.c: Fix for 32-bit lwprint to support
