[postgis-tickets] r15471 - Update news to include 2.3 and add missing upgrade paths
Regina Obe lr at pcorp.us
Fri Jun 30 21:01:25 PDT 2017
Author: robe
Date: 2017-06-30 21:01:25 -0700 (Fri, 30 Jun 2017)
New Revision: 15471
   trunk/NEWS
   trunk/extensions/upgradeable_versions.mk
Modified: trunk/NEWS
--- trunk/NEWS	2017-07-01 03:22:13 UTC (rev 15470)
+++ trunk/NEWS	2017-07-01 04:01:25 UTC (rev 15471)
@@ -15,7 +15,60 @@
  * Bug Fixes *
   - #3682, Boolean (FTLogical) should be 1 byte not 2 bytes
+PostGIS 2.3.3
+2017/07/01
+  * Bug Fixes
+  - #3777, GROUP BY anomaly with empty geometries
+  - #3711, Azimuth error upon adding 2.5D edges to topology
+  - #3726, PDF manual from dblatex renders fancy quotes for programlisting
+           (Mike Toews)
+  - #3738, raster: Using -s without -Y in raster2pgsql transforms
+           raster data instead of setting srid
+  - #3744, ST_Subdivide loses subparts of inverted geometries
+           (Darafei Praliaskouski Komzpa)
+  - #3750, @ and ~ operator not always schema qualified in geometry
+           and raster functions. Causes restore issues.
+           (Shane StClair of Axiom Data Science)
+  - #3682, Strange fieldlength for boolean in result of pgsql2shp
+  - #3701, Escape double quotes issue in pgsql2shp
+  - #3704, ST_AsX3D crashes on empty geometry
+  - #3730, Change ST_Clip from Error to Notice when ST_Clip can't compute a band
+PostGIS 2.3.2
+2017/01/31
+  * Bug Fixes
+  - #3418, KNN recheck in 9.5+ fails with index returned tuples in wrong order
+  - #3675, Relationship functions not using an index in some cases
+  - #3680, PostGIS upgrade scripts missing GRANT for views
+  - #3683, Unable to update postgis after postgres pg_upgrade going from < 9.5 to pg > 9.4
+  - #3688, ST_AsLatLonText: round minutes
+PostGIS 2.3.1
+2016/11/28
+  * Bug Fixes
+  - #1973, st_concavehull() returns sometimes empty geometry collection
+           (gde)
+  - #3501, add raster constraint max extent exceeds array size limit
+           for large tables
+  - #3643, PostGIS not building on latest OSX XCode
+  - #3644, Deadlock on interrupt
+  - #3650, Mark ST_Extent, ST_3DExtent and ST_Mem*
+           agg functions as parallel safe so they can be parallelized
+  - #3652, Crash on Collection(MultiCurve())
+  - #3656, Fix upgrade of aggregates from 2.2 or lower version
+  - #3659, Crash caused by raster GUC define after CREATE EXTENSION
+           using wrong memory context. (manaeem)
+  - #3665, Index corruption and memory leak in BRIN indexes
+           (Julien Rouhaud of Dalibo)
+  - #3667, geography ST_Segmentize bug
+           (Hugo Mercier of Oslandia)
 PostGIS 2.3.0
 2016/09/26
Modified: trunk/extensions/upgradeable_versions.mk
--- trunk/extensions/upgradeable_versions.mk	2017-07-01 03:22:13 UTC (rev 15470)
+++ trunk/extensions/upgradeable_versions.mk	2017-07-01 04:01:25 UTC (rev 15471)
@@ -22,8 +22,11 @@
 	2.2.2 \
 	2.2.3 \
 	2.2.4 \
+	2.2.5 \
 	2.3.0 \
-	2.3.1
+	2.3.1 \
+	2.3.2 \
+	2.3.3
 # This is to avoid forcing "check-installed-upgrades" as a default
 # rule, see https://trac.osgeo.org/postgis/ticket/3420
