[postgis-tickets] [PostGIS] #3825: Running an ST_Intersect with PostGIS Geography with large extents returns incorrect results.
PostGIS trac at osgeo.org
Fri Sep 1 07:10:48 PDT 2017
incorrect results.
  Reporter:  just7460  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.3.4
 Component:  postgis   |    Version:  2.3.x
Resolution:  wontfix   |   Keywords:  Geography, postgis
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 I didn't look at your examples, but geography can only work with a half-
 hemisphere and from your description it sounds like you are trying to do
 more than that.
 http://postgis.net/docs/manual-2.3/using_postgis_dbmanagement.html#idm1345
 As such I'm marking this as wontfix.  If you have a more specific example
 I can follow and are sure you are not falling into the geography flattened
 illusion, feel free to reopen.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3825#comment:1>
