[postgis-tickets] r15619 - #3499, Clarify distance units in docs for ST_ClusterWithin
Daniel Baston
dbaston at gmail.com
Sun Sep 3 17:14:02 PDT 2017
Author: dbaston
Date: 2017-09-03 17:14:02 -0700 (Sun, 03 Sep 2017)
New Revision: 15619
branches/2.2/doc/reference_measure.xml
Modified: branches/2.2/doc/reference_measure.xml
--- branches/2.2/doc/reference_measure.xml 2017-09-04 00:06:56 UTC (rev 15618)
+++ branches/2.2/doc/reference_measure.xml 2017-09-04 00:14:02 UTC (rev 15619)
@@ -1105,7 +1105,7 @@
<refsection>
<title>Description</title>
- <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</para>
+ <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance. (Distances are Cartesian distances in the units of the SRID.)</para>
<para>Availability: 2.2.0 - requires GEOS</para>
</refsection>
