[postgis-tickets] [PostGIS] #3830: PostgreSQL-10: initialization from incompatible pointer type
PostGIS trac at osgeo.org
Tue Sep 5 12:53:43 PDT 2017
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 strk is this PostgreSQL 10 head? What platform are you on?
 I'm not getting this error compiling against 10
 and neither is debbie.  Debbie's just complaining about interrupt tests
 (her last build was from PostgreSQL 10 checked out 2 hours ago)
 http://debbie.postgis.net:8080/view/PostgreSQL/job/PostGIS_Regress_PGDEV_Weekly/4490/consoleFull
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
   /var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.4/regress/00
 -regress-install/share/contrib/postgis/postgis.sql
 -regress-install/share/contrib/postgis/postgis_comments.sql
 -regress-install/share/contrib/postgis/postgis_proc_set_search_path.sql
 Loading SFCGAL into 'postgis_reg'
 -regress-install/share/contrib/postgis/sfcgal.sql
 -regress-install/share/contrib/postgis/sfcgal_comments.sql
 PostgreSQL 10beta4 on x86_64-pc-linux-gnu, compiled by gcc (Debian
 5.2.1-22) 5.2.1 20151010, 64-bit
   Postgis 2.4.0dev - r15623 - 2017-09-05 18:03:54
   scripts 2.4.0dev r15623
   GEOS: 3.7.0dev-CAPI-1.11.0 16183469
   PROJ: Rel. 4.9.2, 08 September 2015
   SFCGAL: 1.3.0
 Running tests
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  loader/Latin1-implicit .... ok
  loader/mfile .... ok
  dumper/literalsrid ....... ok
  dumper/realtable ....... ok
  affine .. ok
  bestsrid .. ok
  binary .. ok
  boundary .. ok
  cluster .. ok
  concave_hull .. ok
  ctors .. ok
  curvetoline .. ok
  dump .. ok
  dumppoints .. ok
  empty .. ok
  estimatedextent .. ok
  forcecurve .. ok
  geography .. ok
  geometric_median .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  in_encodedpolyline .. ok
  iscollection .. ok
  legacy .. ok
  long_xact .. ok
  lwgeom_regress .. ok
  measures .. ok
  minimum_bounding_circle .. ok
  normalize .. ok
  operators .. ok
  orientation .. ok
  out_geometry .. ok
  out_geography .. ok
  polygonize .. ok
  polyhedralsurface .. ok
  postgis_type_name .. ok
  regress .. ok
  regress_bdpoly .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  regress_management .. ok
  regress_selectivity .. ok
  regress_lrs .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_proj .. ok
  relate .. ok
  remove_repeated_points .. ok
  removepoint .. ok
  reverse .. ok
  setpoint .. ok
  simplify .. ok
  simplifyvw .. ok
  size .. ok
  snaptogrid .. ok
  split .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  swapordinates .. ok
  summary .. ok
  temporal .. ok
  tickets .. ok
  twkb .. ok
  typmod .. ok
  wkb .. ok
  wkt .. ok
  wmsservers .. ok
  knn_recheck .. ok
  temporal_knn .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  frechet .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  interrupt .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg11.0w64/test_112_diff)
 --- interrupt_expected  2017-01-01 03:28:16.619591490 +0000
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg11.0w64/test_112_out
 2017-09-05 18:07:46.799988115 +0000
 @@ -1,4 +1,3 @@
 -NOTICE:  liblwgeom code interrupted
  ERROR:  canceling statement due to statement timeout
 -segmentize interrupted on time
 +segmentize interrupted late: 00:00:00.268367
  1|LINESTRING(0 0,2 0,4 0)
  interrupt_relate .. ok
  interrupt_buffer .. ok
  clipbybox2d .. ok
  subdivide .. ok
  voronoi .. ok
  minimum_clearance .. ok
  in_geojson .. ok
  regress_brin_index .. ok
  regress_brin_index_3d .. ok
  regress_brin_index_geography .. ok
  mvt .. ok
  geobuf .. ok
  mvt_jsonb .. ok
  regress_sfcgal .. ok
  sfcgal/empty .. ok
  sfcgal/geography .. ok
  sfcgal/legacy .. ok
  sfcgal/measures .. ok
  sfcgal/regress_ogc_prep .. ok
  sfcgal/regress_ogc .. ok
  sfcgal/regress .. ok
  sfcgal/tickets .. ok
  sfcgal/concave_hull .. ok
  sfcgal/wmsservers .. ok
  sfcgal/approximatemedialaxis .. ok
  uninstall .
 -regress-install/share/contrib/postgis/uninstall_sfcgal.sql
 -regress-install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4663)
 Run tests: 138
 Failed: 1
 Makefile:303: recipe for target 'check' failed
 make[1]: *** [check] Error 1
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.4/regress'
 GNUmakefile:16: recipe for target 'check' failed
 make: *** [check] Error 1
 Build step 'Execute shell' marked build as failure
 IRC notifier plugin: Sending notification to: #postgis-activity
 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3830#comment:1>
