[postgis-tickets] r15631 - Rework PGSQL_VERSION again so to use 2-digits minor from 10 onward
Sandro Santilli
strk at kbt.io
Tue Sep 5 13:50:40 PDT 2017
Author: strk
Date: 2017-09-05 13:50:39 -0700 (Tue, 05 Sep 2017)
New Revision: 15631
branches/2.3/configure.ac
branches/2.3/libpgcommon/gserialized_gist.c
branches/2.3/postgis/gserialized_estimate.c
branches/2.3/postgis/gserialized_gist_nd.c
See #3614 (for 2.3 branch)
Modified: branches/2.3/configure.ac
--- branches/2.3/configure.ac 2017-09-05 20:37:59 UTC (rev 15630)
+++ branches/2.3/configure.ac 2017-09-05 20:50:39 UTC (rev 15631)
@@ -430,18 +430,22 @@
dnl Note: we extract the major & minor separately, ensure they are numeric, and then combine to give
dnl the final version. This is to guard against user error...
PGSQL_FULL_VERSION=`$PG_CONFIG --version`
PGSQL_MAJOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^0-9]]*\([[0-9]]*\).*/\1/'`
PGSQL_MINOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^\.]]*\.\([[0-9]]*\).*/\1/'`
- PGSQL_MINOR_VERSION=`echo $PGSQL_MINOR_VERSION | sed 's/.*devel.*/0/'`
+ if test "$PGSQL_MINOR_VERSION" = "$PGSQL_FULL_VERSION"; then
+ dnl No match means there's no minor version
+ PGSQL_MINOR_VERSION="0"
+ fi
if test $PGSQL_MAJOR_VERSION -gt 9; then
- dnl ==================================================================
- dnl Starting with PostgreSQL 10, major is the new minor
- dnl This is to prevent things like 10.31 ranking higher than 11.0
- dnl===================================================================
- PGSQL_MINOR_VERSION=0
+ dnl ==================================================================
+ dnl Starting with PostgreSQL 10, we use 2 digits for minor version
+ dnl This is to prevent things like 10.31 ranking higher than 11.0
+ dnl===================================================================
+ PGSQL_MINOR_VERSION=`printf %.2d $PGSQL_MINOR_VERSION`
fi
POSTGIS_PGSQL_VERSION="$PGSQL_MAJOR_VERSION$PGSQL_MINOR_VERSION"
PGSQL_PKGLIBDIR=`$PG_CONFIG --pkglibdir`
Modified: branches/2.3/libpgcommon/gserialized_gist.c
--- branches/2.3/libpgcommon/gserialized_gist.c 2017-09-05 20:37:59 UTC (rev 15630)
+++ branches/2.3/libpgcommon/gserialized_gist.c 2017-09-05 20:50:39 UTC (rev 15631)
@@ -22,7 +22,7 @@
#include "lwgeom_pg.h" /* For debugging macros. */
#include "gserialized_gist.h"
-#if POSTGIS_PGSQL_VERSION >= 100
+#if POSTGIS_PGSQL_VERSION >= 1000
#include <float.h>
#endif
Modified: branches/2.3/postgis/gserialized_estimate.c
--- branches/2.3/postgis/gserialized_estimate.c 2017-09-05 20:37:59 UTC (rev 15630)
+++ branches/2.3/postgis/gserialized_estimate.c 2017-09-05 20:50:39 UTC (rev 15631)
@@ -836,7 +836,7 @@
/* Then read the geom status histogram from that */
-#if POSTGIS_PGSQL_VERSION < 100
+#if POSTGIS_PGSQL_VERSION < 1000
float4 *floatptr;
int nvalues;
Modified: branches/2.3/postgis/gserialized_gist_nd.c
--- branches/2.3/postgis/gserialized_gist_nd.c 2017-09-05 20:37:59 UTC (rev 15630)
+++ branches/2.3/postgis/gserialized_gist_nd.c 2017-09-05 20:50:39 UTC (rev 15631)
@@ -52,7 +52,7 @@
#include <assert.h>
#include <float.h>
#endif
