[postgis-tickets] r15634 - Revert rework of PGSQL_VERSION extraction for PostgreSQL 10+
Sandro Santilli
strk at kbt.io
Tue Sep 5 14:23:18 PDT 2017
Author: strk
Date: 2017-09-05 14:23:18 -0700 (Tue, 05 Sep 2017)
New Revision: 15634
trunk/configure.ac
trunk/postgis/gserialized_estimate.c
trunk/postgis/postgis.sql.in
Reverts r15633 and r15629
For information about PostgreSQL versioning changes, see
https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=69dc5ae408f68c302029a6b43912a2cc16b1256c
Ref #3614
Modified: trunk/configure.ac
--- trunk/configure.ac 2017-09-05 21:11:57 UTC (rev 15633)
+++ trunk/configure.ac 2017-09-05 21:23:18 UTC (rev 15634)
@@ -438,18 +438,14 @@
PGSQL_FULL_VERSION=`"$PG_CONFIG" --version`
PGSQL_MAJOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^0-9]]*\([[0-9]]*\).*/\1/'`
- PGSQL_MINOR_VERSION=`echo $PGSQL_FULL_VERSION | sed 's/[[^\.]]*\.\([[0-9]]*\).*/\1/'`
- if test "$PGSQL_MINOR_VERSION" = "$PGSQL_FULL_VERSION"; then
- dnl No match means there's no minor version
- PGSQL_MINOR_VERSION="0"
- fi
+ PGSQL_MINOR_VERSION=`$PG_CONFIG --version | sed 's/[[^0-9]]*\([[0-9]]\)\.\([[0-9]]\).*/\2/'`
if test $PGSQL_MAJOR_VERSION -gt 9; then
- dnl ==================================================================
- dnl Starting with PostgreSQL 10, we use 2 digits for minor version
- dnl This is to prevent things like 10.31 ranking higher than 11.0
- dnl===================================================================
- PGSQL_MINOR_VERSION=`printf %.2d $PGSQL_MINOR_VERSION`
+ dnl ==================================================================
+ dnl Starting with PostgreSQL 10, major is the new minor
+ dnl This is to prevent things like 10.31 ranking higher than 11.0
+ dnl===================================================================
+ PGSQL_MINOR_VERSION=0
fi
POSTGIS_PGSQL_VERSION="$PGSQL_MAJOR_VERSION$PGSQL_MINOR_VERSION"
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c 2017-09-05 21:11:57 UTC (rev 15633)
+++ trunk/postgis/gserialized_estimate.c 2017-09-05 21:23:18 UTC (rev 15634)
@@ -166,8 +166,8 @@
* More modest fallback selectivity factor
-#define FALLBACK_ND_SEL 0.2
-#define FALLBACK_ND_JOINSEL 0.3
+#define FALLBACK_ND_SEL 0.2
+#define FALLBACK_ND_JOINSEL 0.3
* N-dimensional box type for calculations, to avoid doing
@@ -200,7 +200,7 @@
/* Dimensionality of the histogram. */
float4 ndims;
/* Size of n-d histogram in each dimension. */
float4 size[ND_DIMS];
@@ -209,10 +209,10 @@
/* How many rows in the table itself? */
float4 table_features;
/* How many rows were in the sample that built this histogram? */
float4 sample_features;
/* How many not-Null/Empty features were in the sample? */
float4 not_null_features;
@@ -221,12 +221,12 @@
/* How many cells in histogram? (sizex*sizey*sizez*sizem) */
float4 histogram_cells;
/* How many cells did those histogram features cover? */
/* Since we are pro-rating coverage, this number should */
/* now always equal histogram_features */
float4 cells_covered;
/* Variable length # of floats for histogram */
float4 value[1];
} ND_STATS;
@@ -349,7 +349,7 @@
int i;
double sigma2 = 0;
double mean = avg(vals, nvals);
/* Calculate sigma2 */
for ( i = 0; i < nvals; i++ )
@@ -369,7 +369,7 @@
int d;
int accum = 1, vdx = 0;
/* Calculate the index into the 1-d values array that the (i,j,k,l) */
/* n-d histogram coordinate implies. */
/* index = x + y * sizex + z * sizex * sizey + m * sizex * sizey * sizez */
@@ -396,7 +396,7 @@
char *rv;
int i;
stringbuffer_t *sb = stringbuffer_create();
stringbuffer_append(sb, "{\"min\":[");
for ( i = 0; i < ndims; i++ )
@@ -413,7 +413,7 @@
rv = stringbuffer_getstringcopy(sb);
stringbuffer_destroy(sb);
- return rv;
+ return rv;
@@ -428,10 +428,10 @@
int d;
int ndims = (int)roundf(nd_stats->ndims);
stringbuffer_append(sb, "{");
stringbuffer_aprintf(sb, "\"ndims\":%d,", ndims);
/* Size */
stringbuffer_append(sb, "\"size\":[");
for ( d = 0; d < ndims; d++ )
@@ -445,7 +445,7 @@
json_extent = nd_box_to_json(&(nd_stats->extent), ndims);
stringbuffer_aprintf(sb, "\"extent\":%s,", json_extent);
pfree(json_extent);
stringbuffer_aprintf(sb, "\"table_features\":%d,", (int)roundf(nd_stats->table_features));
stringbuffer_aprintf(sb, "\"sample_features\":%d,", (int)roundf(nd_stats->sample_features));
stringbuffer_aprintf(sb, "\"not_null_features\":%d,", (int)roundf(nd_stats->not_null_features));
@@ -457,7 +457,7 @@
str = stringbuffer_getstringcopy(sb);
return str;
@@ -533,7 +533,7 @@
int d = 0;
POSTGIS_DEBUGF(3, " %s", gbox_to_string(gbox));
nd_box_init(nd_box);
nd_box->min[d] = gbox->xmin;
nd_box->max[d] = gbox->xmax;
@@ -619,12 +619,12 @@
nd_box_overlap(const ND_STATS *nd_stats, const ND_BOX *nd_box, ND_IBOX *nd_ibox)
int d;
POSTGIS_DEBUGF(4, " nd_box: %s", nd_box_to_json(nd_box, nd_stats->ndims));
/* Initialize ibox */
memset(nd_ibox, 0, sizeof(ND_IBOX));
/* In each dimension... */
for ( d = 0; d < nd_stats->ndims; d++ )
@@ -632,14 +632,14 @@
double smax = nd_stats->extent.max[d];
double width = smax - smin;
int size = roundf(nd_stats->size[d]);
/* ... find cells the box overlaps with in this dimension */
nd_ibox->min[d] = floor(size * (nd_box->min[d] - smin) / width);
nd_ibox->max[d] = floor(size * (nd_box->max[d] - smin) / width);
POSTGIS_DEBUGF(5, " stats: dim %d: min %g: max %g: width %g", d, smin, smax, width);
POSTGIS_DEBUGF(5, " overlap: dim %d: (%d, %d)", d, nd_ibox->min[d], nd_ibox->max[d]);
/* Push any out-of range values into range */
nd_ibox->min[d] = Max(nd_ibox->min[d], 0);
nd_ibox->max[d] = Min(nd_ibox->max[d], size-1);
@@ -658,16 +658,16 @@
double ivol = 1.0;
double vol2 = 1.0;
double vol1 = 1.0;
for ( d = 0 ; d < ndims; d++ )
if ( b1->max[d] <= b2->min[d] || b1->min[d] >= b2->max[d] )
return 0.0; /* Disjoint */
if ( b1->min[d] > b2->min[d] || b1->max[d] < b2->max[d] )
covered = FALSE;
if ( covered )
return 1.0;
@@ -676,21 +676,21 @@
double width1 = b1->max[d] - b1->min[d];
double width2 = b2->max[d] - b2->min[d];
double imin, imax, iwidth;
vol1 *= width1;
vol2 *= width2;
imin = Max(b1->min[d], b2->min[d]);
imax = Min(b1->max[d], b2->max[d]);
iwidth = imax - imin;
iwidth = Max(0.0, iwidth);
ivol *= iwidth;
if ( vol2 == 0.0 )
return vol2;
return ivol / vol2;
@@ -724,17 +724,17 @@
#endif
int bmin, bmax; /* Bin min, bin max */
const ND_BOX *ndb;
- /* For each dimension... */
+ /* For each dimension... */
/* Initialize counts for this dimension */
memset(counts, 0, sizeof(int)*num_bins);
smin = extent->min[d];
smax = extent->max[d];
swidth = smax - smin;
/* Don't try and calculate distribution of overly narrow dimensions */
if ( swidth < MIN_DIMENSION_WIDTH )
@@ -746,14 +746,14 @@
for ( i = 0; i < num_boxes; i++ )
double minoffset, maxoffset;
/* Skip null entries */
- ndb = nd_boxes[i];
+ ndb = nd_boxes[i];
if ( ! ndb ) continue;
/* Where does box fall relative to the working range */
minoffset = ndb->min[d] - smin;
- maxoffset = ndb->max[d] - smin;
+ maxoffset = ndb->max[d] - smin;
/* Skip boxes that our outside our working range */
if ( minoffset < 0 || minoffset > swidth ||
@@ -761,19 +761,19 @@
continue;
/* What bins does this range correspond to? */
bmin = num_bins * (minoffset) / swidth;
bmax = num_bins * (maxoffset) / swidth;
POSTGIS_DEBUGF(4, " dimension %d, feature %d: bin %d to bin %d", d, i, bmin, bmax);
/* Increment the counts in all the bins this feature overlaps */
for ( k = bmin; k <= bmax; k++ )
counts[k] += 1;
/* How dispersed is the distribution of features across bins? */
@@ -789,10 +789,10 @@
POSTGIS_DEBUGF(3, " dimension %d: stddev = %.6g", d, sdev);
POSTGIS_DEBUGF(3, " dimension %d: stddev_ratio = %.6g", d, sdev_ratio);
#endif
distribution[d] = range;
return TRUE;
@@ -835,24 +835,24 @@
if ( mode == 2 ) stats_kind = STATISTIC_KIND_2D;
/* Then read the geom status histogram from that */
-#if POSTGIS_PGSQL_VERSION < 1000
+#if POSTGIS_PGSQL_VERSION < 100
float4 *floatptr;
int nvalues;
rv = get_attstatsslot(stats_tuple, 0, 0, stats_kind, InvalidOid,
NULL, NULL, NULL, &floatptr, &nvalues);
if ( ! rv ) {
POSTGIS_DEBUGF(2,
"no slot of kind %d in stats tuple", stats_kind);
return NULL;
/* Clone the stats here so we can release the attstatsslot immediately */
nd_stats = palloc(sizeof(float) * nvalues);
memcpy(nd_stats, floatptr, sizeof(float) * nvalues);
/* Clean up */
free_attstatsslot(0, NULL, 0, floatptr, nvalues);
#else /* PostgreSQL 10 or higher */
@@ -864,11 +864,11 @@
return NULL;
nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
free_attstatsslot(&sslot);
#endif
@@ -915,7 +915,7 @@
"histogram for attribute %d of table \"%s\" does not exist?",
att_num, get_rel_name(table_oid));
return nd_stats;
@@ -948,7 +948,7 @@
elog(ERROR, "attribute name is null");
return NULL;
return pg_get_nd_stats(table_oid, att_num, mode, only_parent);
@@ -972,7 +972,7 @@
int ndims1, ndims2, ndims;
double ntuples_max;
double ntuples_not_null1, ntuples_not_null2;
ND_BOX extent1, extent2;
ND_IBOX ibox1, ibox2;
int at1[ND_DIMS];
@@ -1007,10 +1007,10 @@
s1 = s2;
s2 = stats_tmp;
POSTGIS_DEBUGF(3, "s1: %s", nd_stats_to_json(s1));
POSTGIS_DEBUGF(3, "s2: %s", nd_stats_to_json(s2));
/* Re-read that info after the swap */
ncells1 = (int)roundf(s1->histogram_cells);
ncells2 = (int)roundf(s2->histogram_cells);
@@ -1025,7 +1025,7 @@
ndims1 = (int)roundf(s1->ndims);
ndims2 = (int)roundf(s2->ndims);
ndims = Max(ndims1, ndims2);
/* Get the extents */
extent1 = s1->extent;
extent2 = s2->extent;
@@ -1036,7 +1036,7 @@
POSTGIS_DEBUG(3, "relation stats do not intersect, returning 0");
PG_RETURN_FLOAT8(0.0);
* First find the index range of the part of the smaller
* histogram that overlaps the larger one.
@@ -1044,9 +1044,9 @@
if ( ! nd_box_overlap(s1, &extent2, &ibox1) )
POSTGIS_DEBUG(3, "could not calculate overlap of relations");
- PG_RETURN_FLOAT8(FALLBACK_ND_JOINSEL);
+ PG_RETURN_FLOAT8(FALLBACK_ND_JOINSEL);
/* Initialize counters / constants on s1 */
for ( d = 0; d < ndims1; d++ )
@@ -1078,27 +1078,27 @@
nd_cell1.min[d] = min1[d] + (at1[d]+0) * cellsize1[d];
nd_cell1.max[d] = min1[d] + (at1[d]+1) * cellsize1[d];
/* Find the cells of s2 that cell1 overlaps.. */
nd_box_overlap(s2, &nd_cell1, &ibox2);
/* Initialize counter */
for ( d = 0; d < ndims2; d++ )
at2[d] = ibox2.min[d];
POSTGIS_DEBUGF(3, "at1 %d,%d %s", at1[0], at1[1], nd_box_to_json(&nd_cell1, ndims1));
/* Get the value at this cell */
val1 = s1->value[nd_stats_value_index(s1, at1)];
/* For each overlapped cell of s2... */
do
double ratio2;
double val2;
/* Construct the bounds of this cell */
ND_BOX nd_cell2;
nd_box_init(&nd_cell2);
@@ -1109,22 +1109,22 @@
POSTGIS_DEBUGF(3, " at2 %d,%d %s", at2[0], at2[1], nd_box_to_json(&nd_cell2, ndims2));
/* Calculate overlap ratio of the cells */
ratio2 = nd_box_ratio(&nd_cell1, &nd_cell2, Max(ndims1, ndims2));
/* Multiply the cell counts, scaled by overlap ratio */
val2 = s2->value[nd_stats_value_index(s2, at2)];
POSTGIS_DEBUGF(3, " val1 %.6g val2 %.6g ratio %.6g", val1, val2, ratio2);
val += val1 * (val2 * ratio2);
while ( nd_increment(&ibox2, ndims2, at2) );
while( nd_increment(&ibox1, ndims1, at1) );
POSTGIS_DEBUGF(3, "val of histogram = %g", val);
* In order to compare our total cell count "val" to the
* ntuples_max, we need to scale val up to reflect a full
@@ -1135,7 +1135,7 @@
val *= (s2->table_features / s2->sample_features);
POSTGIS_DEBUGF(3, "val scaled to full table size = %g", val);
* Because the cell counts are over-determined due to
* double counting of features that overlap multiple cells
@@ -1162,7 +1162,7 @@
selectivity = 1.0;
return selectivity;
@@ -1216,7 +1216,7 @@
Node *arg1, *arg2;
Var *var1, *var2;
Oid relid1, relid2;
ND_STATS *stats1, *stats2;
float8 selectivity;
@@ -1266,7 +1266,7 @@
selectivity = estimate_join_selectivity(stats1, stats2);
POSTGIS_DEBUGF(2, "got selectivity %g", selectivity);
pfree(stats1);
pfree(stats2);
PG_RETURN_FLOAT8(selectivity);
@@ -1305,7 +1305,7 @@
ND_STATS *nd_stats; /* Our histogram */
size_t nd_stats_size; /* Size to allocate */
double total_width = 0; /* # of bytes used by sample */
double total_sample_volume = 0; /* Area/volume coverage of the sample */
double total_cell_count = 0; /* # of cells in histogram affected by sample */
@@ -1313,7 +1313,7 @@
ND_BOX sum; /* Sum of extents of sample boxes */
ND_BOX avg; /* Avg of extents of sample boxes */
ND_BOX stddev; /* StdDev of extents of sample boxes */
const ND_BOX **sample_boxes; /* ND_BOXes for each of the sample features */
ND_BOX sample_extent; /* Extent of the raw sample */
int histo_size[ND_DIMS]; /* histogram nrows, ncols, etc */
@@ -1322,7 +1322,7 @@
int histo_cells_target; /* Number of cells we will shoot for, given the stats target */
int histo_cells; /* Number of cells in the histogram */
int histo_cells_new = 1; /* Temporary variable */
int ndims = 2; /* Dimensionality of the sample */
int histo_ndims = 0; /* Dimensionality of the histogram */
double sample_distribution[ND_DIMS]; /* How homogeneous is distribution of sample in each axis? */
@@ -1379,7 +1379,7 @@
null_cnt++;
continue;
/* Read the bounds from the gserialized. */
geom = (GSERIALIZED *)PG_DETOAST_DATUM(datum);
is_copy = VARATT_IS_EXTENDED(datum);
@@ -1389,11 +1389,11 @@
POSTGIS_DEBUGF(3, " skipped empty geometry %d", i);
continue;
/* If we're in 2D mode, zero out the higher dimensions for "safety" */
if ( mode == 2 )
gbox.zmin = gbox.zmax = gbox.mmin = gbox.mmax = 0.0;
/* Check bounds for validity (finite and not NaN) */
if ( ! gbox_is_valid(&gbox) )
@@ -1407,24 +1407,24 @@
if ( mode != 2 )
ndims = Max(gbox_ndims(&gbox), ndims);
- /* Convert gbox to n-d box */
+ /* Convert gbox to n-d box */
nd_box = palloc(sizeof(ND_BOX));
nd_box_from_gbox(&gbox, nd_box);
/* Cache n-d bounding box */
sample_boxes[notnull_cnt] = nd_box;
/* Initialize sample extent before merging first entry */
if ( ! notnull_cnt )
nd_box_init_bounds(&sample_extent);
/* Add current sample to overall sample extent */
nd_box_merge(nd_box, &sample_extent);
/* How many bytes does this sample use? */
total_width += VARSIZE(geom);
/* Add bounds coordinates to sums for stddev calculation */
@@ -1434,7 +1434,7 @@
/* Increment our "good feature" count */
notnull_cnt++;
/* Free up memory if our sample geometry was copied */
if ( is_copy )
pfree(geom);
@@ -1470,13 +1470,13 @@
* Second scan:
* o compute standard deviation
/* Calculate average bounds values */
avg.min[d] = sum.min[d] / notnull_cnt;
avg.max[d] = sum.max[d] / notnull_cnt;
/* Calculate standard deviation for this dimension bounds */
for ( i = 0; i < notnull_cnt; i++ )
@@ -1486,7 +1486,7 @@
stddev.min[d] = sqrt(stddev.min[d] / notnull_cnt);
stddev.max[d] = sqrt(stddev.max[d] / notnull_cnt);
/* Histogram bounds for this dimension bounds is avg +/- SDFACTOR * stdev */
histo_extent.min[d] = Max(avg.min[d] - SDFACTOR * stddev.min[d], sample_extent.min[d]);
histo_extent.max[d] = Min(avg.max[d] + SDFACTOR * stddev.max[d], sample_extent.max[d]);
@@ -1507,7 +1507,7 @@
POSTGIS_DEBUGF(4, " feature %d is a hard deviant, skipped", i);
sample_boxes[i] = NULL;
continue;
/* Expand our new box to fit all the other features. */
nd_box_merge(ndb, &histo_extent_new);
@@ -1517,7 +1517,7 @@
nd_box_expand(&histo_extent_new, 0.01);
histo_extent = histo_extent_new;
* How should we allocate our histogram cells to the
* different dimensions? We can't do it by raw dimensional width,
@@ -1540,7 +1540,7 @@
* At this point, histo_cells_target is the approximate target number
* of cells.
* Some dimensions have basically a uniform distribution, we want
* to allocate no cells to those dimensions, only to dimensions
@@ -1552,7 +1552,7 @@
if ( sample_distribution[d] > 0 )
histo_ndims++;
if ( histo_ndims == 0 )
/* Special case: all our dimensions had low variability! */
@@ -1602,11 +1602,11 @@
POSTGIS_DEBUGF(3, " histo_cells_new: %d", histo_cells_new);
/* Update histo_cells to the actual number of cells we need to allocate */
histo_cells = histo_cells_new;
POSTGIS_DEBUGF(3, " histo_cells: %d", histo_cells);
* Create the histogram (ND_STATS) in the stats memory context
@@ -1656,11 +1656,11 @@
/* Give backend a chance of interrupting us */
vacuum_delay_point();
/* Find the cells that overlap with this box and put them into the ND_IBOX */
nd_box_overlap(nd_stats, nd_box, &nd_ibox);
memset(at, 0, sizeof(int)*ND_DIMS);
POSTGIS_DEBUGF(3, " feature %d: ibox (%d, %d, %d, %d) (%d, %d, %d, %d)", i,
nd_ibox.min[0], nd_ibox.min[1], nd_ibox.min[2], nd_ibox.min[3],
nd_ibox.max[0], nd_ibox.max[1], nd_ibox.max[2], nd_ibox.max[3]);
@@ -1672,7 +1672,7 @@
min[d] = nd_stats->extent.min[d];
max[d] = nd_stats->extent.max[d];
cellsize[d] = (max[d] - min[d])/(nd_stats->size[d]);
/* What's the volume (area) of this feature's box? */
tmp_volume *= (nd_box->max[d] - nd_box->min[d]);
@@ -1707,7 +1707,7 @@
POSTGIS_DEBUGF(3, " at (%d, %d, %d, %d)", at[0], at[1], at[2], at[3]);
while ( nd_increment(&nd_ibox, nd_stats->ndims, at) );
/* Keep track of overall number of overlaps counted */
total_cell_count += num_cells;
/* How many features have we added to this histogram? */
@@ -1726,7 +1726,7 @@
stats->stats_valid = false;
return;
nd_stats->histogram_features = histogram_features;
nd_stats->histogram_cells = histo_cells;
nd_stats->cells_covered = total_cell_count;
@@ -1742,7 +1742,7 @@
stats_slot = STATISTIC_SLOT_ND;
stats_kind = STATISTIC_KIND_ND;
/* Write the statistics data */
stats->stakind[stats_slot] = stats_kind;
stats->staop[stats_slot] = InvalidOid;
@@ -1792,7 +1792,7 @@
/* 2D Mode */
compute_gserialized_stats_mode(stats, fetchfunc, sample_rows, total_rows, 2);
/* ND Mode */
- compute_gserialized_stats_mode(stats, fetchfunc, sample_rows, total_rows, 0);
+ compute_gserialized_stats_mode(stats, fetchfunc, sample_rows, total_rows, 0);
@@ -1863,7 +1863,7 @@
static float8
estimate_selectivity(const GBOX *box, const ND_STATS *nd_stats, int mode)
- int d; /* counter */
+ int d; /* counter */
float8 selectivity;
ND_BOX nd_box;
ND_IBOX nd_ibox;
@@ -1872,8 +1872,8 @@
double min[ND_DIMS];
double max[ND_DIMS];
double total_count = 0.0;
- int ndims_max = Max(nd_stats->ndims, gbox_ndims(box));
-// int ndims_min = Min(nd_stats->ndims, gbox_ndims(box));
+ int ndims_max = Max(nd_stats->ndims, gbox_ndims(box));
+// int ndims_min = Min(nd_stats->ndims, gbox_ndims(box));
/* Calculate the overlap of the box on the histogram */
if ( ! nd_stats )
@@ -1896,7 +1896,7 @@
POSTGIS_DEBUG(3, " in 2d mode, stripping the computation down to 2d");
ndims_max = 2;
POSTGIS_DEBUGF(3, " nd_stats->extent: %s", nd_box_to_json(&(nd_stats->extent), nd_stats->ndims));
POSTGIS_DEBUGF(3, " nd_box: %s", nd_box_to_json(&(nd_box), gbox_ndims(box)));
@@ -1935,7 +1935,7 @@
cell_size[d] = (max[d] - min[d]) / nd_stats->size[d];
POSTGIS_DEBUGF(3, " cell_size[%d] : %.9g", d, cell_size[d]);
/* Initialize the counter */
at[d] = nd_ibox.min[d];
@@ -1945,7 +1945,7 @@
float cell_count, ratio;
ND_BOX nd_cell;
/* We have to pro-rate partially overlapped cells. */
@@ -1955,10 +1955,10 @@
ratio = nd_box_ratio(&nd_box, &nd_cell, nd_stats->ndims);
cell_count = nd_stats->value[nd_stats_value_index(nd_stats, at)];
/* Add the pro-rated count for this cell to the overall total */
- total_count += cell_count * ratio;
- POSTGIS_DEBUGF(4, " cell (%d,%d), cell value %.6f, ratio %.6f", at[0], at[1], cell_count, ratio);
+ total_count += cell_count * ratio;
+ POSTGIS_DEBUGF(4, " cell (%d,%d), cell value %.6f, ratio %.6f", at[0], at[1], cell_count, ratio);
@@ -2006,7 +2006,7 @@
nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, only_parent);
if ( ! nd_stats )
elog(ERROR, "stats for \"%s.%s\" do not exist", get_rel_name(table_oid), text2cstring(att_text));
/* Convert to JSON */
str = nd_stats_to_json(nd_stats);
json = cstring2text(str);
@@ -2037,7 +2037,7 @@
/* Retrieve the stats object */
nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, FALSE);
if ( ! nd_stats )
@@ -2046,10 +2046,10 @@
elog(ERROR, "unable to calculate bounding box from geometry");
POSTGIS_DEBUGF(3, " %s", gbox_to_string(&gbox));
/* Do the estimation */
selectivity = estimate_selectivity(&gbox, nd_stats, mode);
pfree(nd_stats);
@@ -2087,12 +2087,12 @@
text *modetxt = PG_GETARG_TEXT_P(4);
char *modestr = text2cstring(modetxt);
if ( modestr[0] == 'N' )
- mode = 0;
+ mode = 0;
selectivity = estimate_join_selectivity(nd_stats1, nd_stats2);
pfree(nd_stats1);
pfree(nd_stats2);
@@ -2149,7 +2149,7 @@
List *args = (List *) PG_GETARG_POINTER(2);
/* int varRelid = PG_GETARG_INT32(3); */
int mode = PG_GETARG_INT32(4);
VariableStatData vardata;
ND_STATS *nd_stats = NULL;
@@ -2157,7 +2157,7 @@
Var *self;
GBOX search_box;
float8 selectivity = 0;
POSTGIS_DEBUG(2, "gserialized_gist_sel called");
@@ -2168,7 +2168,7 @@
* calculation should take account of the incoming operator
* type and do the right thing.
/* Fail if not a binary opclause (probably shouldn't happen) */
if (list_length(args) != 2)
@@ -2282,7 +2282,7 @@
/* Estimated extent only returns 2D bounds, so use mode 2 */
nd_stats = pg_get_nd_stats_by_name(tbl_oid, col, 2, only_parent);
/* Error out on no stats */
if ( ! nd_stats ) {
elog(WARNING, "stats for \"%s.%s\" do not exist", tbl, text2cstring(col));
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-09-05 21:11:57 UTC (rev 15633)
+++ trunk/postgis/postgis.sql.in 2017-09-05 21:23:18 UTC (rev 15634)
@@ -2778,15 +2778,7 @@
CREATE OR REPLACE FUNCTION _postgis_pgsql_version() RETURNS text
AS $$
- SELECT CASE
- WHEN split_part(s,'.', 1)::integer > 9 THEN
- split_part(s,'.', 1) || LPAD(
- COALESCE(NULLIF(
- split_part(s,'.', 2),
- ''), '0'), 2, '0')
- ELSE
- split_part(s,'.', 1) || split_part(s,'.', 2)
- END AS v
+ SELECT CASE WHEN split_part(s,'.',1)::integer > 9 THEN split_part(s,'.',1) || '0' ELSE split_part(s,'.', 1) || split_part(s,'.', 2) END AS v
FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
$$ LANGUAGE 'sql' STABLE;
