[postgis-tickets] r15639 - #3832, support wide integer fields as int8
Paul Ramsey
pramsey at cleverelephant.ca
Wed Sep 6 10:52:49 PDT 2017
Author: pramsey
Date: 2017-09-06 10:52:49 -0700 (Wed, 06 Sep 2017)
New Revision: 15639
trunk/loader/shp2pgsql-core.c
Since the previous behaviour was to turn them into numerics,
this shouldn't cause any outrageous problems. People
with over-wide fields will still want to use the
"force integer" flag to convert their values down
to int4
Modified: trunk/loader/shp2pgsql-core.c
--- trunk/loader/shp2pgsql-core.c 2017-09-06 16:29:48 UTC (rev 15638)
+++ trunk/loader/shp2pgsql-core.c 2017-09-06 17:52:49 UTC (rev 15639)
@@ -1172,38 +1172,36 @@
- state->field_names[j] = malloc(strlen(name) + 1);
- strcpy(state->field_names[j], name);
+ state->field_names[j] = strdup(name);
/* Now generate the PostgreSQL type name string and width based upon the shapefile type */
switch (state->types[j])
case FTString:
- state->pgfieldtypes[j] = malloc(strlen("varchar") + 1);
- strcpy(state->pgfieldtypes[j], "varchar");
+ state->pgfieldtypes[j] = strdup("varchar");
break;
case FTDate:
- state->pgfieldtypes[j] = malloc(strlen("date") + 1);
- strcpy(state->pgfieldtypes[j], "date");
+ state->pgfieldtypes[j] = strdup("date");
break;
case FTInteger:
/* Determine exact type based upon field width */
if (state->config->forceint4 || (state->widths[j] >=5 && state->widths[j] < 10))
- state->pgfieldtypes[j] = malloc(strlen("int4") + 1);
- strcpy(state->pgfieldtypes[j], "int4");
+ state->pgfieldtypes[j] = strdup("int4");
+ else if (state->widths[j] >=10 && state->widths[j] < 19)
+ state->pgfieldtypes[j] = strdup("int8");
else if (state->widths[j] < 5)
- state->pgfieldtypes[j] = malloc(strlen("int2") + 1);
- strcpy(state->pgfieldtypes[j], "int2");
+ state->pgfieldtypes[j] = strdup("int2");
else
- state->pgfieldtypes[j] = malloc(strlen("numeric") + 1);
- strcpy(state->pgfieldtypes[j], "numeric");
+ state->pgfieldtypes[j] = strdup("numeric");
break;
@@ -1213,19 +1211,16 @@
state->field_names[j], state->widths[j], state->precisions[j]);
if (state->widths[j] > 18)
else
- state->pgfieldtypes[j] = malloc(strlen("float8") + 1);
- strcpy(state->pgfieldtypes[j], "float8");
+ state->pgfieldtypes[j] = strdup("float8");
break;
case FTLogical:
- state->pgfieldtypes[j] = malloc(strlen("boolean") + 1);
- strcpy(state->pgfieldtypes[j], "boolean");
+ state->pgfieldtypes[j] = strdup("boolean");
break;
default:
