[postgis-tickets] [PostGIS] #3606: CGAL/SFCGAL/PostGIS License Implications Clarification Documentation
trac at osgeo.org
Wed Sep 6 13:17:03 PDT 2017
Reporter: thx1138 | Owner: pramsey
Type: enhancement | Status: closed
Priority: high | Milestone: PostGIS 2.5.0
Component: sfcgal | Version: 2.2.x
Resolution: fixed | Keywords: license sfcgal cgal documentation
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
It's not really a common question, and frankly anyone who is twisting
their knickers about it should be equally/more worried that PostGIS itself
is fully GPL. But as the FAQ says: that doesn't matter if you're just
calling SQL on the database. CGAL is using GPL FUD to drive folks to
purchase commercial licenses, just like MySQL does/did. If you are
building an app that actually links CGAL, then you have an issue. Using
PostGIS, you do not.
I added a sentence at r15642, hopefully it doesn't make things worse. I
find that GPL fear makes these conversations very hard at the best of
times.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3606#comment:9>
