[postgis-tickets] r15643 - #3246,	comment in code on the memory behavior of lwcollection_extract()
    Paul Ramsey
    pramsey at cleverelephant.ca
    Wed Sep  6 14:00:52 PDT 2017
Author: pramsey
Date: 2017-09-06 14:00:51 -0700 (Wed, 06 Sep 2017)
New Revision: 15643
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwcollection.c
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2017-09-06 20:14:06 UTC (rev 15642)
+++ trunk/liblwgeom/liblwgeom.h.in	2017-09-06 21:00:51 UTC (rev 15643)
@@ -1056,6 +1056,9 @@
 LWGEOM *lwcollection_getsubgeom(LWCOLLECTION *col, int gnum);
+/* WARNING: the output will contain references to geometries in the input, */
+/* so the result must be carefully released, not freed. */
 LWCOLLECTION* lwcollection_extract(LWCOLLECTION *col, int type);
Modified: trunk/liblwgeom/lwcollection.c
--- trunk/liblwgeom/lwcollection.c	2017-09-06 20:14:06 UTC (rev 15642)
+++ trunk/liblwgeom/lwcollection.c	2017-09-06 21:00:51 UTC (rev 15643)
@@ -362,6 +362,8 @@
 * Takes a potentially heterogeneous collection and returns a homogeneous
 * collection consisting only of the specified type.
+* WARNING: the output will contain references to geometries in the input,
+* so the result must be carefully released, not freed.
@@ -429,6 +431,10 @@
 				geomlist[geomlistlen] = tmpcol->geoms[j];
 				geomlistlen++;
+			if (tmpcol->geoms)
+				lwfree(tmpcol->geoms);
+			if (tmpcol->bbox)
+				lwfree(tmpcol->bbox);
 			lwfree(tmpcol);
