[postgis-tickets] r15656 - Place type decls at the top of code blocks per old
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 7 10:16:33 PDT 2017
Author: pramsey
Date: 2017-09-07 10:16:33 -0700 (Thu, 07 Sep 2017)
New Revision: 15656
trunk/postgis/lwgeom_out_geobuf.c
trunk/postgis/lwgeom_out_mvt.c
trunk/postgis/mvt.c
C standards
Modified: trunk/postgis/lwgeom_out_geobuf.c
--- trunk/postgis/lwgeom_out_geobuf.c 2017-09-07 13:40:42 UTC (rev 15655)
+++ trunk/postgis/lwgeom_out_geobuf.c 2017-09-07 17:16:33 UTC (rev 15656)
@@ -85,6 +85,7 @@
elog(ERROR, "Missing libprotobuf-c");
PG_RETURN_NULL();
#else
+ uint8_t *buf;
struct geobuf_agg_context *ctx;
if (!AggCheckCallContext(fcinfo, NULL))
elog(ERROR, "pgis_asmvt_finalfn called in non-aggregate context");
@@ -93,7 +94,7 @@
PG_RETURN_NULL();
ctx = (struct geobuf_agg_context *) PG_GETARG_POINTER(0);
- uint8_t *buf = geobuf_agg_finalfn(ctx);
+ buf = geobuf_agg_finalfn(ctx);
PG_RETURN_BYTEA_P(buf);
#endif
Modified: trunk/postgis/lwgeom_out_mvt.c
--- trunk/postgis/lwgeom_out_mvt.c 2017-09-07 13:40:42 UTC (rev 15655)
+++ trunk/postgis/lwgeom_out_mvt.c 2017-09-07 17:16:33 UTC (rev 15656)
@@ -127,6 +127,7 @@
PG_RETURN_NULL();
#else
struct mvt_agg_context *ctx;
+ uint8_t *buf;
@@ -134,7 +135,7 @@
PG_RETURN_NULL();
ctx = (struct mvt_agg_context *) PG_GETARG_POINTER(0);
- uint8_t *buf = mvt_agg_finalfn(ctx);
+ buf = mvt_agg_finalfn(ctx);
#endif
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2017-09-07 13:40:42 UTC (rev 15655)
+++ trunk/postgis/mvt.c 2017-09-07 17:16:33 UTC (rev 15656)
@@ -288,8 +288,8 @@
static uint32_t add_key(struct mvt_agg_context *ctx, char *name)
struct mvt_kv_key *kv;
+ size_t size = strlen(name);
kv = palloc(sizeof(*kv));
- size_t size = strlen(name);
kv->id = ctx->keys_hash_i++;
kv->name = name;
HASH_ADD_KEYPTR(hh, ctx->keys_hash, name, size, kv);
@@ -298,11 +298,11 @@
static void parse_column_keys(struct mvt_agg_context *ctx)
- POSTGIS_DEBUG(2, "parse_column_keys called");
TupleDesc tupdesc = get_tuple_desc(ctx);
int natts = tupdesc->natts;
uint32_t i;
bool geom_name_found = false;
+ POSTGIS_DEBUG(2, "parse_column_keys called");
for (i = 0; i < natts; i++) {
#if POSTGIS_PGSQL_VERSION < 110
Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
@@ -442,9 +442,9 @@
static void add_value_as_string(struct mvt_agg_context *ctx,
char *value, uint32_t *tags, uint32_t k)
- POSTGIS_DEBUG(2, "add_value_as_string called");
struct mvt_kv_string_value *kv;
size_t size = strlen(value);
+ POSTGIS_DEBUG(2, "add_value_as_string called");
HASH_FIND(hh, ctx->string_values_hash, value, size, kv);
if (!kv) {
POSTGIS_DEBUG(4, "add_value_as_string value not found");
@@ -463,12 +463,13 @@
static void parse_datum_as_string(struct mvt_agg_context *ctx, Oid typoid,
Datum datum, uint32_t *tags, uint32_t k)
- POSTGIS_DEBUG(2, "parse_value_as_string called");
Oid foutoid;
bool typisvarlena;
+ char *value;
+ POSTGIS_DEBUG(2, "parse_value_as_string called");
getTypeOutputInfo(typoid, &foutoid, &typisvarlena);
- char *value = OidOutputFunctionCall(foutoid, datum);
+ value = OidOutputFunctionCall(foutoid, datum);
POSTGIS_DEBUGF(4, "parse_value_as_string value: %s", value);
add_value_as_string(ctx, value, tags, k);
@@ -552,17 +553,21 @@
POSTGIS_DEBUGF(3, "parse_values natts: %d", natts);
+ char *key;
+ Oid typoid;
+ Datum datum;
if (i == ctx->geom_index)
continue;
- char *key = tupdesc->attrs[i]->attname.data;
- Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
+ key = tupdesc->attrs[i]->attname.data;
+ typoid = getBaseType(tupdesc->attrs[i]->atttypid);
#else
- char *key = tupdesc->attrs[i].attname.data;
- Oid typoid = getBaseType(tupdesc->attrs[i].atttypid);
+ key = tupdesc->attrs[i].attname.data;
+ typoid = getBaseType(tupdesc->attrs[i].atttypid);
#endif
- Datum datum = GetAttributeByNum(ctx->row, i+1, &isnull);
+ datum = GetAttributeByNum(ctx->row, i+1, &isnull);
k = get_key_index(ctx, key);
if (isnull) {
POSTGIS_DEBUG(3, "parse_values isnull detected");
@@ -641,7 +646,8 @@
LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
bool clip_geom)
- POSTGIS_DEBUG(2, "mvt_geom called");
+ AFFINE affine;
+ gridspec grid;
LWGEOM *lwgeom_out = NULL;
double width = gbox->xmax - gbox->xmin;
double height = gbox->ymax - gbox->ymin;
@@ -652,6 +658,7 @@
double buffer_map_xunits = resx * buffer;
double buffer_map_yunits = resy * buffer;
const GBOX *ggbox = lwgeom_get_bbox(lwgeom);
+ POSTGIS_DEBUG(2, "mvt_geom called");
if (width == 0 || height == 0)
elog(ERROR, "mvt_geom: bounds width or height cannot be 0");
@@ -687,7 +694,6 @@
if (lwgeom_out == NULL)
lwgeom_out = lwgeom_clone_deep(lwgeom);
- AFFINE affine;
memset(&affine, 0, sizeof(affine));
affine.afac = fx;
affine.efac = fy;
@@ -697,7 +703,6 @@
lwgeom_affine(lwgeom_out, &affine);
- gridspec grid;
memset(&grid, 0, sizeof(gridspec));
grid.ipx = 0;
grid.ipy = 0;
@@ -738,10 +743,10 @@
void mvt_agg_init_context(struct mvt_agg_context *ctx)
+ VectorTile__Tile__Layer *layer;
POSTGIS_DEBUG(2, "mvt_agg_init_context called");
- VectorTile__Tile__Layer *layer;
if (ctx->extent == 0)
elog(ERROR, "mvt_agg_init_context: extent cannot be 0");
@@ -777,10 +782,15 @@
void mvt_agg_transfn(struct mvt_agg_context *ctx)
+ bool isnull;
+ Datum datum;
+ GSERIALIZED *gs;
+ LWGEOM *lwgeom;
+ VectorTile__Tile__Feature *feature;
+ VectorTile__Tile__Layer *layer = ctx->layer;
+ VectorTile__Tile__Feature **features = layer->features;
POSTGIS_DEBUG(2, "mvt_agg_transfn called");
- VectorTile__Tile__Layer *layer = ctx->layer;
- VectorTile__Tile__Feature **features = layer->features;
if (layer->n_features >= ctx->features_capacity) {
size_t new_capacity = ctx->features_capacity * 2;
layer->features = repalloc(layer->features, new_capacity *
@@ -789,19 +799,18 @@
POSTGIS_DEBUGF(3, "mvt_agg_transfn new_capacity: %d", new_capacity);
- VectorTile__Tile__Feature *feature = palloc(sizeof(*feature));
+ feature = palloc(sizeof(*feature));
vector_tile__tile__feature__init(feature);
ctx->feature = feature;
if (layer->n_features == 0)
parse_column_keys(ctx);
- bool isnull;
- Datum datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
+ datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
if (!datum)
elog(ERROR, "mvt_agg_transfn: geometry column cannot be null");
- GSERIALIZED *gs = (GSERIALIZED *) PG_DETOAST_DATUM(datum);
- LWGEOM *lwgeom = lwgeom_from_gserialized(gs);
+ gs = (GSERIALIZED *) PG_DETOAST_DATUM(datum);
+ lwgeom = lwgeom_from_gserialized(gs);
POSTGIS_DEBUGF(3, "mvt_agg_transfn encoded feature count: %d",
layer->n_features);
@@ -821,20 +830,23 @@
uint8_t *mvt_agg_finalfn(struct mvt_agg_context *ctx)
+ VectorTile__Tile__Layer *layers[1];
+ VectorTile__Tile tile = VECTOR_TILE__TILE__INIT;
+ size_t len;
+ uint8_t *buf;
POSTGIS_DEBUG(2, "mvt_agg_finalfn called");
encode_keys(ctx);
encode_values(ctx);
- VectorTile__Tile__Layer *layers[1];
layers[0] = ctx->layer;
- VectorTile__Tile tile = VECTOR_TILE__TILE__INIT;
tile.n_layers = 1;
tile.layers = layers;
- size_t len = vector_tile__tile__get_packed_size(&tile);
- uint8_t *buf = palloc(sizeof(*buf) * (len + VARHDRSZ));
+ len = vector_tile__tile__get_packed_size(&tile);
+ buf = palloc(sizeof(*buf) * (len + VARHDRSZ));
vector_tile__tile__pack(&tile, buf + VARHDRSZ);
SET_VARSIZE(buf, VARHDRSZ + len);
