[postgis-tickets] [PostGIS] #3836: Parallel support for ST_CountAgg, ST_SummaryStatsAgg
trac at osgeo.org
Thu Sep 7 13:31:54 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by pramsey:
Old description:
> Continuing from #3751.
> * ST_CountAgg
> * ST_SummaryStatsAgg
> These two aggregates are candidates for parallel aggregation. They are
> already marked parallel safe in their current incarnation.
> They require a combinefunc, and serialize/deserialize functions.
> Unfortunately each has several different SQL function parameterizations,
> so it'll be a little complex to carry out.
New description:
* ST_CountAgg
* https://www.postgresql.org/docs/9.6/static/sql-createaggregate.html
* https://www.postgresql.org/docs/9.6/static/xaggr.html#XAGGR-PARTIAL-
AGGREGATES
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3836#comment:1>
